  SoarerCentral * Bodywork and Exterior * Windscreen wiper rubber Previous Previous    Next Next
Open in new windowArchive through July 31, 2005Peter Burrett16
Steve Millward
Monday, August 01, 2005 - 10:13 am, by:  Steve Millward Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the help.
The reason I put the post on was because my rubbers had the thin metal strips that Mike refers to, which are very different to the ones I'd seen in shops. The car was first imported in 1996, and I can't believe that they are the original wipers (I know we don't get much rain but that would be ridiculous), so I'm assuming that Lexus were able to source some originals.
I got some from Super Cheap Auto, and they work a treat.
Jeff Wilkins
JZZ30 GT-TL
Monday, August 01, 2005 - 05:53 pm, by:  Jeff Wilkins Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive so far tried 3 different sets of wiper blades, all from autobahn. So far they have all been utter crap! Sweeping downward they do fine, going the other way they jump all over the place :-(
I was considering sourcing a '95+ wiper arm with the wind deflector thing built in, but if theres rubbers available at Super Cheap then...
Super Cheap here I come.
Simon Triantafillou
Soarer Turbo
Monday, August 01, 2005 - 06:28 pm, by:  Simon Triantafillou Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I use the Trico ones as well without any problems. Keep the window clean, and it's just like when the car rolled out of the factory.
Soarer GT Limited (4.0L V8) and is300 (3.0L il6)
Monday, August 01, 2005 - 07:05 pm, by:  David Vaughan Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil, where would you get that? Is it a standard Toyota part? Do you have them? I happen to need a rear wiper now. The front ones I replaced with something-or-other from autObarn and they are working OK but not great.
(Autobahn is the German freeway Jeff; autObarn just trades on the idea.
Uh oh. Peter Burrett's going to tell me I'm being pedantic again)
Jeff Wilkins
JZZ30 GT-TL
Monday, August 01, 2005 - 08:28 pm, by:  Jeff Wilkins Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And he'd be correct David, but pedantic is ok. Shows just how much attention I pay to their signs and advertisement. May as well save themselves the money and not bother.
peter lang
uzz31 soarer ltd v8
Monday, August 01, 2005 - 10:04 pm, by:  peter lang Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The original blades with the metal strips are BOSCH brand about $30 a set. we fit about 3-4 sets a day, but the best advice is clean the glass regularly and even the cheap ones will work well (for a while)
Rob Middleton
91 UZZ31 LTD,91 JZZ30 GTL,93 JZZ30 GTT
Monday, August 08, 2005 - 11:36 am, by:  Rob Middleton Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I use trico commodore VR-VT inserts which you cut to lenght normally around $17. The advice re European fitment is right, but it works best with the original soarer insert arms, if you look the passenger one is curved and is marked with a (P).Also the drivers one is stamped (D) is straight but longer.With a clean screen they work beautifully.
Monday, August 08, 2005 - 01:37 pm, by:  Vinh Bui Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just purchased the one's from Super Cheap Auto, and did a test the moment I got home. It did very well, compared to my previous one's anyway haha.
Anish Varsani
V8 UZZ30
Sunday, August 14, 2005 - 09:29 am, by:  Anish Varsani Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm about change my wipers. What's the best way to get calcium (I think) stains off the glass?
At some stage in the car's life, it was washed but not wiped off.
Sunday, August 14, 2005 - 11:19 am, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You could try what I use, which is fine grade steel wool (obtainable from supermarkets etc).
Clean windscreen first, then while WET, use the steel wool.
Go over the ENTIRE screen, paying particular attention to the areas that are covered by the arc of the wipers.
Keep the screen wet at all times.
You'll know it's fully cleansed when you don't feel a "Drag" from the steel wool.
Rinse screen thoroughly, and dry with a clean lint free towel, fit NEW wiper refills.
Drive & enjoy the clarity
Steve Patterson
2x V8 LTD's
Sunday, August 14, 2005 - 11:44 am, by:  Steve Patterson Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used a clay bar on my windscreen, it worked pretty good.Upload
I'm not sure if it's meant to be used on glass though..
Sunday, August 14, 2005 - 12:08 pm, by:  Don Bagnall Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Steve, a clay Baaa will work in a similar fashion, but steel wool is easier & cheaper to purchase
Yogeeshanth Raviraj
Monday, September 26, 2005 - 12:05 pm, by:  Yogeeshanth Raviraj (Yogz22tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just bought wipers from super cheap auto and they worked a treat. I bought the Aunger Brand with silicone and they wipe very clean up and down. I spent $10
Jeff Wilkins
JZZ30 GT-TL
Monday, September 26, 2005 - 04:16 pm, by:  Jeff Wilkins (Calin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ditto that! I bought the aunger silicones a few weeks ago, work bloody well.
