  SoarerCentral * Say G'day * Jimmy's car's 56K warning Previous Previous    Next Next
James Macarin
Soarer z20, Supra A70, Cresta jzx81
Reg: 07-2007
Tuesday, July 24, 2007 - 08:34 pm, by:  James Macarin (Jimmy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello
I thought I may take this opportunity to introduce myself.
I have owned a jza70 a few years back now. After this car I decided to build up my a70 spare parts shell into a running car. It started off of a ma70 and under went a total transformation to look and handle like a jza70 spec R. I did all the work myself on this conversion and in January this year it became road registered. I wouldn't suggest anyone go to the extent to change over every bit of wiring and interior unless you had to as its a time consuming process. Currently the car is under going surgery to hopefully hit the magical 500bhp mark with the aid of a gt35r turbo and a few other goodies. Its going to be mainly used on the track for drifting.
Mods are
Supra 89 ma70
1JZGTE + r154
GT35r turbo
Custom manifold
48mm TURBOSMART wastegate
Hybrid Intercooler
Os giken gearset
650cc Injectors
HKS 256 cams
Blitz ecu (to be replaced shortly)
Profec B boost controller
1350kg pressure plate
6 button clutch
Greddy Boost gauge
Omori gauges (oil temp, oil pressure, water temp)
Apexi N1 exhaust
Cusco Zero 2 coilovers
Front and rear strut brace
Torsen lsd (to be replaced for a 2 way)
Bomex body kit (front bar, side skirts, rear pods)
S02 Wide body guards (only one in Australia)
RAYS 57 Pro rims 18x9 and 18x10
Cusco bolt in roll cage
Random Japanese fixed back race seats
SARD fuel regulator
There is lots more but I cannot think right now exactly what is left.
Pictures of build up, none once it came off the road to get single turbo conversion done.
Also I have got a jzx81 Cresta for my daily when I get around to fixing it up. Has the 1jz and auto box. basically stock standard.
Now the soarer.
I bought this as someone else's unfinished project. It has been totally stripped down to a bare shell.
Soarer 84 GZ20
Mods
Weight reduction (no spare wheel, sound deadening, gutted doors etc)
Carbon fibre dash
Carbon fibre bonnet
Carbon fibre boot
Fuel cell
Surge tank
Full Chrome molly roll cage
Wider front guards (not in pictures)
Front strut brace
Pictures
Future plans are to import myself a 2jz package with around 500-600bhp.
Upgrade all the brakes to supra 4 pot with use of Ikea formula z30 control arms and z30 hubs to also allow more steering lock.
Motec ecu and dash.
Then race it in classic Adelaide and also the Targa Tasmania.
Here is a quick video of my old car out at the track.
http://vid105.photobucket.com/albums/m233/ma701jz/Jza70drift.flv
Wednesday, July 25, 2007 - 12:22 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow! That is a lot of work! Keep the pics and information coming. :-)
Nathan Evans
1JZZ30 TT
Wednesday, July 25, 2007 - 04:41 pm, by:  Nathan Evans (Soarer7) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i like the red racing seat in the supra, very nice!
Marc Vipond
JZZ30 GT35R
Reg: 05-2006
Wednesday, July 25, 2007 - 04:59 pm, by:  Marc Vipond (04awe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damn man that is a wicked collection of toyota history there!
James Macarin
Reg: 07-2007
Wednesday, July 25, 2007 - 06:32 pm, by:  James Macarin (Jimmy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey pen. I met you at the soarer day down on king william road. I was saying I had a few goodies :-)
Yes there is a lot of work put into these cars, I don't think they will ever be finished but that is a project car for you. Engine in supra is coming out to finish it all off and hopefully it can stay in there for a long time.
I would not say this is a "collection of toyota history" as most of these cars will get driven harder than most could ever dream of and i'm building them to survive that. I found these older cars feel a lot nicer to drive and more raw which makes them more exciting.
If people in SA need parts for the a70/z20 I have a lot of stuff spare or can track it down quite easily.
Cheers for reading and I will hopefully have more pictures and videos soon.
Andrew Cox
Perth
Soarer V8 Ltd
Reg: 05-2007
Wednesday, July 25, 2007 - 07:16 pm, by:  Andrew Cox (400sc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I like the Ma70 reminds me of my mates one it was basically that exact same set up and colour it went hard! pity it ended up smashed around a light pole not long after being built
James Macarin
Reg: 07-2007
Wednesday, July 25, 2007 - 07:59 pm, by:  James Macarin (Jimmy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The supra is being resprayed shortly as well to the late model a80 dark silver.
And still deciding if I want to put a gold pearl over the soarer.
Andrew, what was your mates name?
Andrew Cox
Perth
Soarer V8 Ltd
Reg: 05-2007
Thursday, July 26, 2007 - 05:26 pm, by:  Andrew Cox (400sc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt not sure of his last name his used to have the plates 1JZGTE in perth
Brendan McGannon
s.a
JZZ30 GT30/37 factory manual
Reg: 05-2006
Monday, August 13, 2007 - 06:07 pm, by:  Brendan McGannon (1jzspec) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
can i upload vids of front lawn skids WITHOUT the red racing seat!
Monday, August 13, 2007 - 07:17 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Soarer Central is not able to host videos.
James Macarin
Reg: 07-2007
Monday, August 13, 2007 - 07:55 pm, by:  James Macarin (Jimmy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think he wants to upload it onto a place like photobucket, you tube etc so people can see. I think a go kart would have been more complete than my car at this point in its build. Consisted of, chassis, engine, gearbox, diff, 2 front seats, steering wheel and suspension. It didn't have, doors, bumpers,head lights, tail lights, interior, front panels (none!) didn't have an exhaust either.
True jimmy style, cars running and within 5 minutes its doing circle work on the front lawn.
