  SoarerCentral * General Soarer Chat * Starting the car after 9months Previous Previous    Next Next
Shaun Kim
Sunday, September 16, 2007 - 02:29 pm, by:  Shaun Kim (Smk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well i just came back from my long working holiday and i just need some information on what i should do to get my soarer on the road.
it hasnt been driven or even started the last 9months. anything that i should do to get the soarer running? I got some new batteries for starters... any info will be much appreciated
thanks
Kyle Wathen
GTTL
Reg: 02-2007
Sunday, September 16, 2007 - 04:24 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Drain the petrol and put some fresh stuff in there.
A quick oil change would also be a good idea.
Sunday, September 16, 2007 - 04:43 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I would suggest, Oil + filter change, coolant flush, fresh petrol, And also a Brake fluid flush ( brake fluid is renouned for absorbing water particles.. its not a km based thing, more a time factor).
Mike Bradberry
V8 UnLimited
Sunday, September 16, 2007 - 04:49 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm not sure if priming the injectors might also be an issue.
V8 Ltd manual
Sunday, September 16, 2007 - 05:43 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Synthetic oils in use can last a year so nine months in storage is practically irrelevant.
Filters accumulate nothing while there is no flow.
Petrol will deteriorate a little but the car will go until you fill it up again.
Radiator fluid lasts for years when you use the car and does not die when you do not.
Brake fluid is hygroscopic but if you would not flush it in nine months of use then why would you flush it in nine months of non-use?
Do you warm up the car fully before you drive it? Well, don't do that either.
Start the bloody thing and drive it. Fill up with petrol and go for a longer drive. Then get a normal service depending on whether you did one just before you laid it up.
Sunday, September 16, 2007 - 05:54 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I guess I dhould have asked, When was its last service?
If the brake Fluid hasnt been changed for aalmost 2 years prior to the break, i would recommend it..
I would be changing it all for peace of mind. And at least you know where your service intervals start from again:-)
Shaun Kim
Monday, September 17, 2007 - 12:13 am, by:  Shaun Kim (Smk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cheers guys~
guess a normal service will do the trick as its due for one...
by the way when i started the car this morning there was a "lot" of smoke from the exhaust~ is that normal?
Soarer VVTi
Monday, September 17, 2007 - 07:16 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably condensation from starting it after such a long time.
Mustafa Akgul
Big Mac
Monday, September 17, 2007 - 09:44 am, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shaun Kim wrote on Monday, September 17, 2007 - 12:13 am:
is that normal
yes like Jose said condensation and soarers run very rich on cold start up wich can also cause black smoke.
