  SoarerCentral * General Soarer Chat * Steering wheel play Previous Previous    Next Next
Aaron Thorburn
auckland
v8
Tuesday, November 20, 2007 - 06:44 pm, by:  Aaron Thorburn (Azzabazza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys and girls, put 18" deepies on the soarer and after the car was pulling to the left quite badly i took it into a shop to get a wheel alignment and that showed up that there is some play in the steering wheel, meaning that the wheel can be gently moved from side to side and the wheels on the ground do not react at all, has anyone had this problem or can anyone help me out with what i can do to fix this, its cruise season and i'd love to have my responsive steering back again
thanks
azza.
Darryn Dewar
Gisborne
UZZ30 Soarer
Tuesday, November 20, 2007 - 08:13 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Steering rack bushes
Shaun Stephenson
Jzz30 TT & ST162
Tuesday, December 04, 2007 - 05:40 pm, by:  Shaun Stephenson (Neonasty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
*agrees with Darryn*
Do a search, its been covered many times.
Celsior UCF11 V8
Tuesday, December 04, 2007 - 06:35 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Would steering rack bushes also be responsible for a sort of clunking steering wheel over angle bumps and slopes? as the steering wheel in my celsior tends to make soft popping sounds further down in the steering column by the sounds of it. Its rather annoying.
Wednesday, December 05, 2007 - 09:04 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Could be - that or worn knuckles - though that usually also leads to vague steering and lack of response. Could also be ball joints etc.
