  SoarerCentral * General Soarer Chat * Cleaned Soarer pictures Previous Previous    Next Next
Soarer JZZ31 I6 & UCF11 V8 Celsior
Saturday, January 05, 2008 - 04:53 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Now that my Soarer 3.0GT is a fair bit more presentable from when I first got it, Heres a few pictures of how its starting to shape up.
Few things left to do but as a whole its comming up great. So far put the TT wheels on it and given the paint some TLC. Note the BFI too - Superb upgrade sounds terrific and balances the car out well compared to stock.
Ill have more pictures in the future as I do my upgrades here and there as usual. :-)
Saturday, January 05, 2008 - 06:10 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very nice Mr.Beck...............carry on
Saturday, January 05, 2008 - 07:00 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ohhh yes, indeed
Sunday, January 06, 2008 - 07:46 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What did you use to clean the engine bay Mike? Mine is way overdue - last time I just used CRC and rags but wasn't too happy with the results, so if you have any advice...?
Sunday, January 06, 2008 - 09:01 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All I do is get a can of WD40, giving the entire bay a good spray, covering up some of the areas where I dont want water to go.
Let it sit for a minute or two.
Then mist the WD40 off with a light misty spray from the hose till thats milky look when water/wd40 mixes.
Give the panels and overs in the bay a wipe down and around all the drity areas with a rag.
Then get a blow vac, a compressor would be better and air dry the engine bay getting water out so its nearly dry.
Comes up good and only takes 5-10 minutes
