  SoarerCentral * General Soarer Chat * Advice wanted! Previous Previous    Next Next
Karen Farmer
Reg: 12-2007
Friday, January 18, 2008 - 03:57 pm, by:  Karen Farmer (Angel_wings) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Everyone
I am very new to Soarers and have had mine for about a mnth.
I have been having some thoughts to add some modds to my stock engine and would like some advice.
I dont want to do alot, just want a bit more power without it costing me a fortune. Would a boost controller and maybe a better intercooler do? Or any other thoughts?
Will Schultz
new south wales
tt
Reg: 05-2007
Friday, January 18, 2008 - 04:15 pm, by:  Will Schultz (Johnny_dangerous) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just did dumps,exhaust,fmic and the results were great.
I think a lot of people would agree its a good place to start
Adrain Parsons
JZZ30 tt
Friday, January 18, 2008 - 07:08 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
first thing to do is a BFI...
Justin Cook
Saturday, January 19, 2008 - 06:40 am, by:  Justin Cook (Justin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think min. with best results (listed from cheapest to not so cheap).
*BFI DIY!
*Manual boost controller (don't turn it up too much) although these controllers are notorious for spiking (get an electronic if you can afford it). Say 12psi.
*FMIC (won't add much more power, but always a good thing for engine safety).
*Exhaust (oh yeah! Big bang for buck here)
*Dump pipes! ($580 from lew) then install will be a bit (unless you can do it, big job removing turbos).
*Turn up previously bought boost controller to 14psi :-)
If you do your turbos GO a responsive SINGLE! Don't stuff around with twins :-) Twice as expensive (I learned the hard way!) That is unless you find someone selling a twin kit, who has spent all the money for you!
Saturday, January 19, 2008 - 08:14 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Definitely fix the breathing first; dumps and a better exhaust will help in a big way ;D
A bleed valve can be an inexpensive boost controller but can also be dangerous =P
