  SoarerCentral * General Soarer Chat * Coolants: LLC Red vs SLLC Pink - what are the differences? Previous Previous    Next Next
Edward Salem
Aristo 3.0V TT
Reg: 01-2007
Sunday, January 20, 2008 - 03:33 pm, by:  Edward Salem (Sydeward) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just recently I had my radiator properly flushed and refilled at the local toyota service centre. I had the cheap green no name coolant which came with the car replaced with genuine Pink Toyota Super Long Life coolant for piece of mind.
The cooling system was pressure tested and is fine, the only thing concerning me now is im being told that I shouldve used the Red Long life coolant which the car was designed to use...
Upon researching the two types of coolant ive struggled to find any key differences between the two. Yes Pink is rated to last 100-150,000kms whereas red will last 50,000kms meaning pink has more preserving additives than the red type. Pink is premixed and red is sold as a 100% concentrate thus needs to be diluted with water. Pink is nearly 4x more expensive although both are Ethyl Glycol based anti freeze coolants.
So what is the difference? Quoting what ive seen around the internet the pink SLLC apparently is designed for newer model toyotas, although can be used on cars which would usually run on LLC Red coolant. The car im referring to is my 2JZGTE Aristo 3.0V. I was hoping someone could shed some light on any other possible differences between the two types of collant and thus help me decide if the pink SLLC is sufficient for my car :-)
Monday, January 21, 2008 - 02:34 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The impression I got was that the pre-mix had water added, but they increased the "life expectancy" to make it look better and sell better. At a much higher price. The argument was that the premix would be the right concentration.
Edward Salem
Aristo 3.0V TT
Reg: 01-2007
Wednesday, January 30, 2008 - 08:59 pm, by:  Edward Salem (Sydeward) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well I ended up going for the pink coolant. its far from cheap, but being premixed long life it will work to maximum efficiency, thus eliminating any human error which could occur while mixing the coolant. id expect it to have better corrosion protection as well being rated at 150,000k's but I guess time will tell
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Wednesday, January 30, 2008 - 09:20 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You mean pink as they actually call it pink? Or it just looks pink as it is pre-mixed?
Edward Salem
Aristo 3.0V TT
Reg: 01-2007
Wednesday, January 30, 2008 - 09:25 pm, by:  Edward Salem (Sydeward) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i got the premixed super long life coolant. I suppose itd look the same as the LL Red coolant once its been mixed anyways
Thursday, January 31, 2008 - 02:56 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The catch is, if there is any water/coolant left in the block after a flush or drain, then the mixture is no longer accurate.
That is why I prefer the concentrate, as I can add 1/2 the capacity of the cooling system, then top up with distilled or demineralised water, and know it will be right. :-)
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Thursday, January 31, 2008 - 07:23 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have an easy way of knowing whether mine is the right concentration, if my rad doesn't explode when it's -51 with the wind chill like it was on monday morning then it's probly ok
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Thursday, January 31, 2008 - 09:01 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott Ferguson wrote on Thursday, January 31, 2008 - 07:23 am:
More power to you, bro!!BRRRRRRRRRR!
It's a chilly 60 F down here! Dang, 111 degrees difference!!
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Thursday, January 31, 2008 - 09:12 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ummm -51 degrees Celcius, that's -60 F
Dave Billings
Louisiana
Reg: 06-2007
Thursday, January 31, 2008 - 10:22 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dang...120 difference! I don't see how you all can do that...survive, I mean! LOL
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Saturday, February 02, 2008 - 01:48 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pfft... the puny little american can't handle the cold? Hahahah i'm just giving you a hard time Dave, It's cold alright but i don't think anyone enjoys it.
Steven Nanevski
D Day has almost arrived....
Saturday, February 02, 2008 - 10:50 am, by:  Steven Nanevski (Imprestik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
-51 degrees celcius Holy crap..........
Man and we whinge here in winter when it's 10 degrees celcius...
How the hell do you get out of bed in that temperature??
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Tuesday, February 05, 2008 - 07:04 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
VERY reluctantly.
