  SoarerCentral * General Soarer Chat * Acceleration Previous Previous    Next Next
Peter Nardini
Alberta
Monday, March 03, 2008 - 05:35 pm, by:  Peter Nardini (Calgary1987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK so I got my soarer last year at Halloween last year and drove it for 1 month before parking it for the winter.
The acceleration when I first got the car was awesome. I got it up to 180kmh with no problem. So now winter is done here in Canada and I took the tarps off of it.
Over the winter the water pump seal cracked. I was able to tell this when the first time I took it out, the engine started to smoke and I took it into a shop and they did the timing belt and water pump.
After getting it back from the shop now, the acceleration sucks. The same stretch of road that I got it up to 180 I can barely get it up to 145. I need your help guys. What happened? What should I do?
Charlie Ters
TT gone single :-)
Reg: 01-2007
Monday, March 03, 2008 - 07:04 pm, by:  Charlie Ters (Ul05st) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
your timing sounds like it is out..... get your timing checked :-)
