  SoarerCentral * General Soarer Chat * Key and Ignition Help.. Previous Previous    Next Next
Tim McMullin
Alberta
Reg: 05-2007
Thursday, March 27, 2008 - 04:03 am, by:  Tim McMullin (Dirty380) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys..I tried searching but didn't find much on ignition removal. So don't flame!
I've lost my only key to my soarer. (God damn alchohol..haha:-)) Anyways, I have had a lock smith remove the trunk lock in hopes he could get a code from the lock and cut a key. He managed to cut a key that gets into the car and can lock it..but it does not start the vehicle. It can be put into the ignition switch..unlock the steering wheel..but it won't turn over.
So basically I am stuck..
Is there place on a different lock that I can get removed that will have my key code on it? Is there a database I can cross check with that anybody has access to?
Also, I think I could remove the whole ignition itself..I just need some guidance. Is ignition removal in depth??
Please guys..any tips, tricks, insight on this matter would be great. I can't get to work..you can see my problem.
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Thursday, March 27, 2008 - 04:09 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Call Toyota...they can cut you a factory key, but it won't be cheap!
Tim McMullin
Alberta
Reg: 05-2007
Thursday, March 27, 2008 - 05:31 am, by:  Tim McMullin (Dirty380) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have spoken to the Toyota dealership here in Canada. They need a 16 digit VIN number..as you know soarers have 12 (I think) so they can't do that.
Dave Billings
Louisiana
Reg: 06-2007
Thursday, March 27, 2008 - 05:57 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Really? My SC has 17...weird.
Dave Billings
Louisiana
Reg: 06-2007
Thursday, March 27, 2008 - 06:20 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh, BTW. A few years ago my gf locked my keys in the trunk so the only dealership I could find that could do it was in New York...kinda close to you. Good Luck!
Darryn Dewar
Gisborne
UZZ30 Soarer
Thursday, March 27, 2008 - 07:46 am, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The key code should be on the drivers side door lock.
However I haven't taken mine out to check
Gavin Smith
2.4 TD
Reg: 01-2008
Thursday, March 27, 2008 - 10:44 am, by:  Gavin Smith (Gavs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Reason why the cut key won't turn over the engine is that inside the key fob, there's generally a teeny tiny transponder that communicates with a sensor in your ignition. If the transponder code doesn't match/is non existent, the car will not start. If you can get the locksmith the key's code, he should be able to make up a replacement coded key. I know because I do the same think, although where I do part time work, we need an original key to get the signal code, whereas proper locksmiths can program from scratch, if they know what they're doing.
Tim McMullin
Alberta
Reg: 05-2007
Thursday, March 27, 2008 - 01:58 pm, by:  Tim McMullin (Dirty380) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys.
Gavin I am aware that I need to get him the code. But, like I said he tried that with the numbers that were supposedly on the trunk lock and again..like I said..it doesn't make the car turnover.
Dave: Could you give me their numbeR?
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Thursday, March 27, 2008 - 04:28 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tim, your trunk lock might be from another car, with the barrel re-configured for your key.
Try the driver's door lock, as it's more likely the original lock and barrel (boots tend to get changed with wings and rear accidents, doors tend to get re-skinned, using original frame and utilities).
B.
Dave Billings
Louisiana
Reg: 06-2007
Friday, March 28, 2008 - 12:40 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wish I could remember that number, Tim. I went to the Lexus dealership here in New Orleans and they told me that the only dealership that could do it was in New York, so technically I didn't deal with them personally, my dealer did...sorry!
