  SoarerCentral * Bodywork and Exterior * Will 92 fog lights fit a 95 front bar ? Previous Previous    Next Next
Ben James
Queenland
Twin Turbo : )
Sunday, October 30, 2005 - 02:20 pm, by:  Ben James (Silverbullet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I need to know if 92 soarer fog lights will fit a 95 front bar,they look very similar, just need to know if they will fit and wire up ok ? also how do I remove my fog lights ?
Mustafa Akgul
JZZ30-GTTL
Sunday, October 30, 2005 - 02:49 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no as the 95 is bigger and has raised section..
Black/Black JZZ30 VVTi
Monday, October 31, 2005 - 02:33 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And the 91~93 use turning lamps, the bulbs are different between the two.
Ben James
Queenland
Twin Turbo : )
Monday, October 31, 2005 - 08:32 pm, by:  Ben James (Silverbullet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So there is no way to make them fit ?
Thursday, November 03, 2005 - 09:38 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No, just pick up some 94~96 fog lights and rig the wiring to fit H3 bulbs.
