  SoarerCentral * General Soarer Chat * DANG Seatbelts! Previous Previous    Next Next
Peter Nardini
Alberta
Thursday, May 22, 2008 - 02:58 pm, by:  Peter Nardini (Calgary1987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Both of my seat belts wont retract and dont provide any safety at all. They just stay loose and wont retract.
What should I do to fix them?
Or should I just buy new seat belts?
Blake Davies
S A
Factory 5sp TT
Thursday, May 22, 2008 - 06:54 pm, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would buy new seat belts!
I'm not sure if you can fix seat belts
Mark Donovan
Wellington
Soarer V8 Limited
Thursday, May 22, 2008 - 07:50 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
buy new ones, but you may find drivers side is only available in black.
I went through the hassle of having mine re-webbed after being promised much better retraction only to have them returned with perhaps zero improvement. I got to keep the grey plastic surround, the grey arm and a new belt but was left unimpressed with both customer service and lack of promised results.
Good luck.
Kyle Wathen
GTTL
Reg: 02-2007
Thursday, May 22, 2008 - 08:53 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Which company did you use Mark?
You can buy Soarer belts from Toyota or aftermarket manufacturers Peter.
Peter Nardini
Alberta
Friday, May 23, 2008 - 03:38 am, by:  Peter Nardini (Calgary1987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The Toyota dealership new seabelts would cost me $400 each belt plus instaltion
IRAQ
XTR T-66
Friday, May 23, 2008 - 03:55 am, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
400 each ! BAH.
just buy some second hand ones and install em yourself, its not that hard.
Should be plenty of sets getting around with all the wrecking of soarers going on, i reckon they would even post to you in ALBERTA !
Mark Donovan
Wellington
Soarer V8 Limited
Wednesday, June 04, 2008 - 06:04 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kyle, I actually used a company in Perth, believe it or not. I feel so dumb for having done so. I can't recall their name at the moment but they were recommended here on SC. I have the receipt but it's in a box that's en route from Wellington.
