  SoarerCentral * Air Conditioning and Climate Control * Air Condition Fan Not Running Previous Previous    Next Next
Firoz Akbar
Reg: 11-2008
Monday, December 15, 2008 - 11:54 am, by:  Firoz Akbar (Hackfifi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys..I recently bought a 95 2.5L TT..I am having a problem with the A/C.It just doesn’t seem to blow any air at all.I am assuming the fan is down.I’ve checked the fuse, and I replaced the A/C Console, but no luck.
If any of you guys can provide some input at what I should check, or recommend an air-con specialist in Perth, it would be much appreciated.
Thanks...
Firoz
Harley Jones
jzz30
Reg: 03-2009
Wednesday, April 01, 2009 - 04:33 pm, by:  Harley Jones (Dvjzz30) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im at the same position..although nothing appears on the lcd screen of mine either, is this the same for you firoz?
