  SoarerCentral * General Soarer Chat * Trac Control Wont Turn Off Previous Previous    Next Next
Brett Callaughan
VVT-i Turbo
Tuesday, November 01, 2005 - 01:02 pm, by:  Brett Callaughan (Snkmst) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
My traction control seems to be on and when i press the button just on the underside of the dash nothing happens. any ideas.
Thanks,
Tuesday, November 01, 2005 - 03:34 pm, by:  Morgan Cross (Morgan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you want it removed completely, you can pop the bonnet and remove the TRC fuse!
I'm not too sure about what circuit it's on or which fuse it's related to sorry, :-)
UZZ32 ( V8 )
Tuesday, November 01, 2005 - 03:44 pm, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Why is your trac button on the underside of the dash?
Did they move it in later years from near the gear lever?
UZZ30 GT4.0 V8
Tuesday, November 01, 2005 - 03:49 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good point Sir Perry
Mark Paddick
Soarer UZZ31
Tuesday, November 01, 2005 - 05:14 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
...maybe they found a cheaper alternative!!
Toyota want $385 for the Trac/TEMS/Height switch assy
UZZ30 GT4.0 V8
Tuesday, November 01, 2005 - 07:29 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How reasonable
Brett Callaughan
VVT-i Turbo
Tuesday, November 01, 2005 - 09:01 pm, by:  Brett Callaughan (Snkmst) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The button is located where the drivers left knee would be i will take a photo tomorrow.
UZZ32 V8 Soarer #183
Wednesday, November 02, 2005 - 06:17 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe the globe in the dash has blown??
Sean Routledge
V6 Ecotec
Reg: 07-2008
Friday, July 11, 2008 - 11:48 pm, by:  Sean Routledge (Stircrazy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is the red button with jap writing the TRC button??
Darryn Dewar
Gisborne
UZZ30 Soarer
Friday, July 11, 2008 - 11:53 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope (Talk about a thread from the past....)
