  SoarerCentral * Track and Major Rebuild Car Projects * Tune up Previous Previous    Next Next
John Summergreene
N.S.W.
v8
Reg: 09-2011
Sunday, April 21, 2019 - 12:36 pm, by:  John Summergreene (Easigonjack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Had my twin turbo fail an emission test in Sydney due to it running too lean. Does anyone know a reputable person to tune it.
Blake Gloyn
manawatu
soarer JZZ30 TT
Friday, April 26, 2019 - 06:59 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So they ere failing the car for not putting enough unburnt petrol into the atmosphere? I don't get it.
Goetz von Gneisenau
Reg: 03-2019
Friday, April 26, 2019 - 08:07 pm, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
High NOx emissions can occur when an engine's air-fuel mixture is too lean. ... This could be caused by a problem with the vehicle's oxygen sensor, malfunctioning air flow and coolant sensors or a leak in the fuel system.
They obviously have limits on how high NOx emissions can be..
Mark Tierney
JZZ30 GTT-L Built 1.5JZ Beast, UCF11, IS250, GS350-FSport, Ducati SS
Wednesday, May 01, 2019 - 10:02 am, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is it stock? Are you running an aftermarket EMS or boost controller ?
