  SoarerCentral * General Soarer Chat * What could this noise be? Previous Previous    Next Next
David Murray
SC400 V8
Reg: 04-2007
Monday, August 11, 2008 - 04:53 pm, by:  David Murray (David) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the video quality isn't great just done with the digital camera, but the noise comes through clear enough. What could it be?
http://www.youtube.com/watch?v=GgIN-2bkCCQ
Monday, August 11, 2008 - 05:38 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Power steering Pump Bearing shot? Idler pulley bearing shot? Hydraulic Fan ?
David Murray
SC400 V8
Reg: 04-2007
Monday, August 11, 2008 - 06:31 pm, by:  David Murray (David) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks for your input, I'm booked in at the mechanics on Thursday, it also seems to only make this noise when the car is cold if that makes a difference.
David Murray
SC400 V8
Reg: 04-2007
Monday, August 11, 2008 - 06:34 pm, by:  David Murray (David) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm a bit of a retard when it comes to mechanics in cars would the Idler pulley bearing cause the car to idle weird if it was stuffed?
Monday, August 11, 2008 - 11:52 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope, its just another pulley that keeps things moving...
Nothing wrong with asking questions mate :-) Thats how you get answers..
Do let us know the result of the issue though :-)
