  SoarerCentral * General Soarer Chat * Removing Suspension Previous Previous    Next Next
David Grab
T78
Reg: 01-2008
Friday, August 15, 2008 - 04:53 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys im removing my suspension right as we speak. Anyway for what ever reason i cant seen to have the rotor assembly drop so i can pull out my coilovers. Im used to Nissans with two bolts but never done it on a Soarer before. Can anyone link me to a tutorial or show me which bolts need to be removed on a diagram? Ideally i'd like to get them done today so any help would be awsome. Im pretty sure there is one bolt that im not removing and that’s why it not dropping. I might be wrong but hopefully someone who is in the know can tell me.
-Dave-
Friday, August 15, 2008 - 05:37 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David, 2 bolts should allow the callipers to be removed.
See if the pics here help.
http://soarer.ace.net.au/brake_pads.html
Chris Prak
Soarer GTT-L
Reg: 12-2006
Friday, August 15, 2008 - 06:50 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/cgi-bin/sc-forum/show.cgi?tpc=30604&post=264585#POST264585
Chris Prak
Soarer GTT-L
Reg: 12-2006
Friday, August 15, 2008 - 06:54 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is also another way, by removing the large/long bolt that holds the wishbone (the one further away from you), then you are able to drop/spin at the same time to get it out.
BTW: Peter must have had a long day...
