  SoarerCentral * Bodywork and Exterior * Removing Door Sills Previous Previous    Next Next
Jason Cheah
Wednesday, November 16, 2005 - 11:00 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone have the instructions or have done it before? Thanks.
Andreas Niaouris
W.A.
Thursday, November 17, 2005 - 03:25 pm, by:  Andreas Niaouris (Andreasn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
G'day Jason, plenty of stuff available for this topic.
For starters try this sit, it has photo's as well.
http://www.microtech.com.au/~cheets/soarer_door_trim_problem.htm
Thomas Mulraney
Thursday, November 17, 2005 - 03:34 pm, by:  Thomas Mulraney (Mxt_imports) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've done it before Jason, once you actually get up close and have a look its pretty straight forward. All up, first time I did the passenger door it took me about 1/2 hr to get it off and on. While your at it, tighten the bolts holding in the woodgrain, as these can come loose over time and causes the woodgrain to vibrate. Very annoying, especially when driving!! Good luck anyway, its a pretty easy, straightforward procedure
Thomas Mulraney
Thursday, November 17, 2005 - 03:35 pm, by:  Thomas Mulraney (Mxt_imports) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
By the way, to the club, very nice looking car you've got there!
Jason Cheah
Thursday, November 17, 2005 - 05:43 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks... but I think i did not state the question quite specifically...
I was referring to Door Sills, not Door Trims.
Exact name would be Door Sill Plates or Scuff plates. like this one.
http://www.vftbushes.com/images/scuffs1.jpg
Its the black piece of plastic.
Sorry for the confusion. Thanks again.
By the way, I'm not new to the club, just that I re-registered to Soarer Central from the old ALSC forum. Been a member since 2002.
1991 UZZ30 GT4.0 V8
Thursday, November 17, 2005 - 08:30 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jason, ya just get a good grip on one end, and pull firmly upwards. It will release itself from the retaining clips.
Jason Cheah
Thursday, November 17, 2005 - 08:57 pm, by:  Jason Cheah (Freaky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Don. That's the answer I was looking for. I actually wanna do that today, but was afraid i might miss something. So decided to check over here first.
Andreas Niaouris
W.A.
Friday, November 18, 2005 - 03:06 pm, by:  Andreas Niaouris (Andreasn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oopsie!!
sorry Jason,
Thanks Don :-)
