  SoarerCentral * Bodywork and Exterior * Who can clean and reaseal headlights in VIC Previous Previous    Next Next
Patrick Chan
Friday, April 07, 2006 - 12:57 am, by:  Patrick Chan (Kittz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey
Just wondering who can fix up the headlights from moisture and reaseal them in melbourne?
Also does anyone know what number are for the blue globes instead of the standard ones for the low beam and high beams?
Thanks
3.0 GT
Friday, April 07, 2006 - 06:56 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Patrick,
Why not give it a go yourself? Its really a very easy job, just time consuming. Follow the tutorials that are around - but you only need to set the oven to around 100 degrees (at least for my fan forced oven) and leave the light in for about 5 minutes. Make sure you get as much of the grey sticky crap off as you possibly can - it comes off pretty easy when its hot.
Friday, April 07, 2006 - 10:33 am, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Patrick,
You can check out Melbourne Headlight Exchange or Sports & luxury Cars.
They both can fix up yours headlights and reseal them.
Ryan Rankovic
Soarer TT GT-TL
Friday, April 07, 2006 - 12:15 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew, do you pre heat the oven to 100? or just throw the lights in, set oven to 100, and leave for 5 mins?
Friday, April 07, 2006 - 01:16 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ryan Rankovic wrote on Friday, April 07, 2006 - 12:15 pm:
When the little "Winkie" pops out, the headlights are done.
Remove from oven, baste with a rich brown gravy, rest for 10 mins, and serve on a platter with vegetables.
Garnish with fresh Parsley.
Add salt & pepper to taste
Kanchana Pathirana
3ltr straight 6
Friday, April 07, 2006 - 01:39 pm, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
seriously patrick do it yourself, i did mine using the tute from here bout 2 months ago....they still not resealed tho. i used a heat gun and a spatular thing, wasnt even a proper tool, thats how easy it is. at the moment am putting in angel eyes. did one yesterday, doing one now waiting it to dry on the chrome thing as i speak.
Ryan Rankovic
Soarer TT GT-TL
Friday, April 07, 2006 - 02:03 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don Bagnall wrote on Friday, April 07, 2006 - 01:16 pm:
Thats made me sooo hungry Don
Friday, April 07, 2006 - 04:34 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, nice Eh!.
For din-dins tonight, Karen is presenting me with Scotch Fillet, Bacon, Mushrooms, Acid free Tomatoes, Chips and Fried eggs...........NOICE!
Dave Hart
Waikato
UZZ32
Friday, April 07, 2006 - 05:05 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don, shouldn't that be Scotch and fillet?
Friday, April 07, 2006 - 05:33 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nooooooooooooo!.........BOURBON ONLY!!!
Dave Hart
Waikato
UZZ32
Friday, April 07, 2006 - 05:42 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, shouldn't that be a bourbon fillet?
Friday, April 07, 2006 - 05:57 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Err!...Umm!......Maybe?
3.0 GT
Monday, April 10, 2006 - 07:10 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yup, I took all the clips off first, unscrewed the mounting bracket and any other screws I could find, then I pre-heated to 100 degrees on fan forced bake, put the light on a dish cloth on an oven tray (to stop hot metal being in contact with the plastic) and left it for 5 minutes. Took it out and levered it apart with a butter knife - removed the reflectors and then popped it back it for a bit to re-heat the gray sticky crap so I could scrape it all off with the butter knife. Simple.
Ashleigh Coles
vic
sc400 V8
Saturday, April 15, 2006 - 09:09 am, by:  Ashleigh Coles (Clash) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i just took my lights apart and was wondering if you can use sikaflex to re glue them together
Michael James
V8 UZZ31 Limited
Saturday, April 15, 2006 - 09:27 pm, by:  Michael James (Wildwizard) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
D-Mastic to stick them back together, unless you like the idea of something going wrong with the seal and not been able to get them apart to re-clean them.
Norfolk Island
Sunday, April 16, 2006 - 12:47 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I practiced on a cheap (Soarer-like) light from EBay. Other than cutting my fingers on glass floating around (the lens had been damaged) it was reasonably easy.
The grey goo looked a lot like Sikaflex, as mentioned, so I wonder if anyone has tried it? I can get that at the hardware store, but not D-Mastic.
I also wonder, what is the point removing the old goo? One might as well just reheat and reseal with the old stuff. Apparently, this isn't where the lights let moisture in, anyway. You could always run a small bead of sealer around the outside, after reattaching the halves.
Patrick Chan
Sunday, April 16, 2006 - 04:46 pm, by:  Patrick Chan (Kittz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just put my car to luxury cars its only $80 for a headlight and fixed and everything so its pretty cheap and i'll get them to change the orange globe to a clear one aswell.
What headlights fits the soarers which are blue?
Does anyone have the product code so I can purchase a pair?
Norfolk Island
Sunday, April 16, 2006 - 05:50 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I assume you're talking about bulbs/globes, Patrick? They are available cheaply off EBay, make sure you get the right ones and you'll need to modify 9005 ones. Technically they real ones are 9005J but these are only available (apparently) from the original Koito (yellow!!) and PIAA (Expensive!!)
These globes (the EBay ones) appear to be made made China as the sellers are usually in Hong Kong. I have several sets, one 65W uncapped for the high beams didn't work on receipt, the others, including H3 for '97 fogs and H1 for the Wizard, work fine. It was a pain modifying the 9005s for high and low beam though.
Most guys here appear to just chop the lugs but I found the whole lug came off so a Dremel tool is better (although slow and messy).
To confuse matters some local Au cars were modified during compliance to take 9006 (like US cars) so you'd better check.
These are equivalent to HB3 and HB4- someone else better tell you which is which I always forget:-)
Ashleigh Coles
vic
sc400 V8
Monday, April 17, 2006 - 10:47 am, by:  Ashleigh Coles (Clash) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have just purchased a soarer half cut and i can try with the lights in that to see if sikaflex works or not
Monday, April 17, 2006 - 02:07 pm, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Patrick,
There is a set of (TOYOTA SOARER JZZ30) Head light globs (PIAA)for sale on ebay and maybe you want to check it out.
3.0 GT
Tuesday, April 18, 2006 - 06:49 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike Triggs wrote on Sunday, April 16, 2006 - 12:47 pm:
Mostly because when you pull it apart it does a melted cheese impersonation and goes all over the place.
Norfolk Island
Tuesday, April 18, 2006 - 08:25 am, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Sharpe wrote on Tuesday, April 18, 2006 - 06:49 am:
The one I practiced on ( not a Soarer light, but similar) didn't do this too badly. I seem to recall from Peter Nitschke's tutorial, that he suggested keeping the old stuff due to the hassle of getting it off.
Tuesday, April 18, 2006 - 12:47 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Personal choice. I removed it, but it adds to the workload.
3.0 GT
Wednesday, April 19, 2006 - 06:43 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I just figured that it was easier to get rid of it than to try and make it look tidy again once it was back together. But I guess it doesnt really matter what it looks like as nobody is ever really going to look at it. Didn't take too long to get rid of it, just re-warm, scrape, re-warm, scrape...
