  SoarerCentral * General Soarer Chat * Removing the front bar - found a 'surprise' Previous Previous    Next Next
Doran Guthrie
VVTI Turbo
Reg: 10-2007
Saturday, October 25, 2008 - 07:55 pm, by:  Doran Guthrie (Dozzly) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've had my soarer for quite a while and like to think of myself a quite soarer savy. 99% of the mods and repairs I've done myself from suspension to intake even ecu BUT today was the first time I've needed to take the front bar off and dammit, my baby's bubble just burst.
Yup, the front left impact bar seems not to exist. Apart from the jagged appendage, the exterior is immaculate with no panel warp or paint mismatch. How the hell could I miss it??
The sad thing is that I'll never look at my baby the same again......
Ben Lipman
Soarer TT manual
Saturday, October 25, 2008 - 08:41 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was under my track car today to fit a tow hook, and discovered I don't have one at all!
Benjamin Anderson
tas
v8
Reg: 09-2008
Saturday, October 25, 2008 - 08:54 pm, by:  Benjamin Anderson (Chicken) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't worry, i'm sure it's happened to most of us.
After 5 weeks of ownership I lifted up my rear seat, to find butchered wiring and missing tv, nav and radio controllers, which explains some of my electrical issues
Joel King
Reg: 11-2007
Sunday, October 26, 2008 - 08:26 am, by:  Joel King (Twinturbos_rock_my_chasis) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Original Poster:
Are you referring to the shiny metallic thing(The "reo")?
I am assuming they are the same as common doors and are removable, why not go to a wrecker or get one off a half cut /wreck? Will give you piece of mind at least :-)
I believe mostly you can buy them off the manufacturer also, if you were that way inclined...
And no offence but some ones written their shopping list on your car
Edit: to make you feel better I heard about a guy that had a car for two years (Nissan 180sx) and let rego slip once, whilst getting it blue slipped they discovered it had the entire front section of the chassis from the doors forward welded to the back.... ended up being unroadworthy....
Scott Casey
soarer v8
Reg: 02-2008
Sunday, October 26, 2008 - 03:37 pm, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
when my brother car (blownminiturbo) was resprayed and vertex bodykit was installed. the smash repairer was not going to put it back on and said that in the repair notes they have for the toyota soarer's was optional to put the intrusion bar back on so we said not paying for nothing till its put on. this was after they sprayed and fitted the bodykit.
just get one from a wrecker
Soarer DUB Edition
Sunday, October 26, 2008 - 10:31 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Doran, stage 1 weight reduction !
Lachie Bryce
vic
Jzz31
Reg: 03-2008
Monday, October 27, 2008 - 02:37 pm, by:  Lachie Bryce (Caboose) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Doran Guthrie wrote on Saturday, October 25, 2008 - 07:55 pm:
you soarer could always cry and try to act like it hurts...
Glen Muller
V8 Soarer UZZ31
Reg: 12-2007
Tuesday, October 28, 2008 - 07:50 pm, by:  Glen Muller (Doom_and_gloom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wouldn't either if it had those decals on it
Ben Kelly
Wentworthville
v8
Tuesday, October 28, 2008 - 08:29 pm, by:  Ben Kelly (Ace) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Doran since you got all the decals and no electrics maybe you should turn it into a track car?
Doran Guthrie
VVTI Turbo
Reg: 10-2007
Tuesday, October 28, 2008 - 10:23 pm, by:  Doran Guthrie (Dozzly) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I agree, but its needs less panel damage and a bloody huge aluminium wing stickin 3 foot in the air first. Mind you, I do subscribe to the 'if ya got it, tell everyone' method of cruisin.
