  SoarerCentral * Air Conditioning and Climate Control * Resistor codes for aircon? Previous Previous    Next Next
Brett Harris
2.5TT
Reg: 09-2008
Saturday, November 22, 2008 - 11:06 am, by:  Brett Harris (Stay_beautiful) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have just replaced my resistor with another second hand unit and noticed not all the numbers are the same.
Start the same with "RH" then "766" but the last lot change
The choices I have seen are 10M(on Mine), 5L an the replacement and 7L in the tutorial.
Does this mean anything or are they interchangeable?.
Also noticed that when I removed the replacement one(5L) as nothing changed with fan speeds, that it was really hot.
Do I need to look at other things to get all my fan speeds back(I have low and high)?
