  SoarerCentral * General Soarer Chat * Unichip ecus Previous Previous    Next Next
Andrew Keddie
vic
2.5TT soarer
Reg: 02-2008
Wednesday, January 07, 2009 - 12:33 am, by:  Andrew Keddie (Boozer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does anybody know what features these come with. like do they have fuel cut, speed cut. does anybnody know, cheers
Wednesday, January 07, 2009 - 06:08 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ONly licensed workshops can tune them. Some have mentioned a short lifespan with them also, ie, failed after 3-4 years depending on the model or batch?
David Shaw
Supercharged and Intercooled UZZ31
Reg: 12-2008
Wednesday, January 07, 2009 - 08:07 am, by:  David Shaw (Shawy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah my Unichip ECU is being run with my supercharger on my V8 31 and I gotta say the first performance change ill b making will be to get rid of that and replaced it with a stand alone ECU but running it through a piggyback. It just doesn't allow for enough play with the fuel line and transmission so ya get some annoying problems when you start to approach big KWs :-( I would suggest forking out the cash initially for a more advanced ECU that way you don't have to worry about it ever again! :-) That said though it might suit you well for a relatively cheap mod. Gotta remember ya get what ya pay for though! :-)
Andrew Keddie
vic
2.5TT soarer
Reg: 02-2008
Wednesday, January 07, 2009 - 10:10 am, by:  Andrew Keddie (Boozer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
am i better off sticking with an emanage blue
(even though no-one in geelong will install and tune it)
Scott Casey
soarer v8
Reg: 02-2008
Wednesday, January 07, 2009 - 11:01 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
www.etuner.com.au
cihan.jzz30@gmail.com
0412 531 849
he is in melbourne
Ryan Rankovic
Soarer TT GT-TL
Wednesday, January 07, 2009 - 01:29 pm, by:  Ryan Rankovic (Ryan1j) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott Casey wrote on Wednesday, January 07, 2009 - 11:01 am:
www.etuner.com.au
0412 531 849
he is in melbourne
TR44i
Wednesday, January 07, 2009 - 05:46 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am selling an Emanage Blue with plug in harness and a speed cut defender wired into the plug in harness... installation will take about 1 minute if your quick... :-) Then get Cihan to tune it for you. Installation wont cost you anything... PM me if you are keen.
Kyle Wathen
JZZ30 Manual GT-T
Reg: 02-2007
Wednesday, January 07, 2009 - 07:04 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What ECU will you be using Morgan?
Wednesday, January 07, 2009 - 09:38 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maurice is sellin up...
