  SoarerCentral * General Soarer Chat * Stalling soarer Previous Previous    Next Next
Tony Kaldes
Reg: 04-2008
Saturday, January 17, 2009 - 02:08 pm, by:  Tony Kaldes (Ydeny4) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
G'day to all fellow soarer owners,
I've recently come across what i hope is a small problem. Last week i let the missus borrow my car and she didnt realise that the overdrive button was off, she drove it down the freeway for about half an hour in 3rd gear. When she got off the freeway, for some reason everytime she went to turn left the car choked then stalled. She let the car rest for about half an hour then it seemed fine for a bit then did it again. When she got the car home it seemed ok when i drove it but after about half an hour of driving it started to do the same thing for me too. Strange thing is that turning right seems to have no effect, its only when turning left. Has anyone come across this problem before???
Saturday, January 17, 2009 - 07:02 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Low fuel?
Sunday, January 18, 2009 - 01:27 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Loose battery terminal? And maybe loose battery?
The O/D button is irrelevant.
Tony Kaldes
Reg: 04-2008
Monday, January 19, 2009 - 06:19 pm, by:  Tony Kaldes (Ydeny4) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fuel was 3/4 full and battery/ battery terminals are 100% tight. It seems to do it more regularly when the car is warmer. Also if i dont accelerate when turning she doesnt stall, but if i try pressing the accelerator while turning she chokes straight away and stalls. Still hasnt done it once when turning right though. WTF???
Tuesday, January 20, 2009 - 01:34 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has to be something loose that is moving. Might be tricky to find though. Does the clock etc ever reset?
Tony Kaldes
Reg: 04-2008
Tuesday, January 20, 2009 - 03:52 pm, by:  Tony Kaldes (Ydeny4) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Got the blinking dash problem and the bottom of the screen very rarely turns on, and when it is visible it only shows me the error messages. But i dont think it does reset cause everything else is fine. I spent about half an hour checking all the connections, intercooler piping, wires and other random things but everything is looking pretty good. Unfortunately where i live there are only about 4 or 5 soarers around so the mechanics arent familiar on how to work on them. Thanks for trying to help guys.. Wish me luck
Christian Molenda
T
Wednesday, January 21, 2009 - 08:38 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fuel Pump ECU.. Search and you will find the fix. (bridge FP and B+ in Diagnostics port in engine bay with piece of wire)
If it stops doing it then you know its the fuel pump ecu.
Also i reapair blinky dash's. PM Me for more info if you want.
Thanks
Tony Kaldes
Reg: 04-2008
Thursday, January 22, 2009 - 09:05 pm, by:  Tony Kaldes (Ydeny4) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok cheers i will give that a try when i get a chance on the weekend. Fingers crossed
