  SoarerCentral * Test Post and Forum Issues * What Is This Thing?? Pic Included Previous Previous    Next Next
Justin Green
sa
SC400/Soarer V8
Reg: 01-2009
Monday, January 12, 2009 - 07:30 pm, by:  Justin Green (Jaay_dogg) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What is this Black cylinder with the yellow sticker on it next to the brake fluid? Is it to do with the brakes? I sometimes hear it turn on for a few seconds when my ignition is switched on, but engine not running, is that normal?
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Monday, January 12, 2009 - 09:48 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its the nitrogen charged canister for the power brake system, assists the master cylinder.
Chris Lock
sa
Reg: 03-2008
Monday, January 12, 2009 - 10:01 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
and yes it's normal.
If you hear it go off every few seconds when the car is running, then you need to replace it.
Darren Warner
Monday, January 19, 2009 - 11:13 pm, by:  Darren Warner (Dmwheelers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Taplin can supply you with a reco unit. I had one fitted to mine and all good now
