  SoarerCentral * General Soarer Chat * V8 Soarer vs VS supercharged v6 Previous Previous    Next Next
James Buchan
UZZ31 V8
Reg: 10-2008
Wednesday, September 02, 2009 - 09:34 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A friend has just bought one. You guys are probably sick to death of these stupid threads asking which car would beat which. I do realise it seems like a school holiday question, but I'm genuinely interested as to see what the result would be, at least in a straight line, as around a corner, there is no contest, my Soarer will pull away with the trd bilsteins.
Heres what redbook had to say on the specs.
http://www.redbook.com.au/used-cars/details.aspx?R=69861&__Qpb=true&Cr=3&__Ns=p_Make_String|
Christian Somerville
UZZ31 V8
Reg: 03-2009
Wednesday, September 02, 2009 - 09:37 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Soarer dude, my soarer is stock and can keep up with my mates 200kw HSV, so no chance for that commy...
James Buchan
UZZ31 V8
Reg: 10-2008
Wednesday, September 02, 2009 - 09:42 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha, nice! I'll be getting the major service done soon, new plug leads, & so on. After that it'll either be a piggy back ecu or headers. That statesman will stand no chance
James Cahir
Reg: 04-2008
Wednesday, September 02, 2009 - 10:02 pm, by:  James Cahir (James987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't write off the L67 just yet. I remember back in 1997 Motor or Wheels magazine ran a 14.6 quarter mile time in a VS Calais super 6. The Stato would be around 0.5 seconds slower. Remember that the gun HSV's of the day ran mid to low 14's down the quarter.
Wednesday, September 02, 2009 - 10:03 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Stock v8 runs 15.4ish for the 1/4 . Stock Vs Supercharged V6 might crack a mid 15 as well .. Would be pretty close .
Andrew Duaso
Reg: 02-2009
Wednesday, September 02, 2009 - 10:09 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sc commo is a heap, a magna 3.5 WAS faster the manual magnas were intothe high 14's stock. No bs!
But anyway who cares cos my grannie will dust you in an Aurion totally stock and well into the 14's
game over!
Lol
James Buchan
UZZ31 V8
Reg: 10-2008
Wednesday, September 02, 2009 - 10:16 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the input fellas. It's an interesting comparison, I think stock for stock they'd be pretty close. Guess it's anyones guess as to which would win?
Jeff Harper
UZZ32 Active V8
Wednesday, September 02, 2009 - 10:26 pm, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ummm, "Soarer dude, my soarer is stock and can keep up with my mates 200kw HSV"
May I humbly suggest your mate needs to practise his launch, or drive it like he stole it.
My UZZ30 with a Mines and stripped interior got 15.19 for the 1/4.
220kw Commos get 12~13 second passes all the time.
Andrew Duaso
Reg: 02-2009
Wednesday, September 02, 2009 - 10:51 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dude he's talking about 200kw commos back in the day like when they had 200 at the engine not the wheels and did 15's
the 5.0l iron block good sounding but slow std. Vr vs etc....
Let's not forget we have almost 200kw and a better useable rev range than the old 5l
I smashed the 185i stato that a guy from work owns easily and over and over..... But big deal...... Rember the local preist driving that V6 camry that goes harder than a GTHO and gets under 10l/100km
end of the day the V8 soarer seems to be under rated it goes very well for a car of it's era! Forget comparing it to a new car, compare it to the other large sedans from the early 90's back when 15 sec 1/4's where still fast....
Jol Alexander
Reg: 07-2009
Thursday, September 03, 2009 - 09:02 am, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am confused here... I own a UZZ31 nd have owned a VS and a VT.
A Turbo'd(supercharged) VS should be able to destroy a Soarer V8 ... the V8 is just so "slow" to build up speed. It it was a rolling start then yeah it would b a fair race ..but from the christmas tree the turbo'd car should whoop the UZZ
That being said - add a Supercharger to the Soarer and it would rape the como without any drama
Andrew Duaso
Reg: 02-2009
Thursday, September 03, 2009 - 09:32 am, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dude your missing the point here
factory supercharged 3.8L Holden
they made 172kw and 180kw in the hsv XU6 that's flywheel not at the wheels...
Modified they will go better.... But let's compare stock to stock...
Your soarer must be in need of repair because mine takes of very well now off the line, it has a stuffed afm and was a slug till high rpm but it goes well now... Totally stock other than straight through rear mufflers and resonators in place of the mid mufflers, full tank on the heavy gangster 20's subs and in the boot and it was doing 15.3-5's on the gtech pro rr. Compare it to a mid 16 sec vat from the same era and the ols clapped out soarer still holds it's own even today. Not bad considering the age and general lack of maintainence on these old beasts. I had an EF full system and intake on it and it did 16.4's same size car same capacity newer model yet still slower and no where near as nice. I think cos it's a V8 soarer forgetting that it's old and just 4l everyone expects it to be a rocketship. I rember commos of the same era had just 165kw from their 5L engines and the std VL 5.0L had 122kw all flywheel.....
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Thursday, September 03, 2009 - 10:00 am, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew - might need you to come around and test drive my soarer. Its such a smooth ride maybe its in my head that it's sluggish :-)
Andrew Duaso
Reg: 02-2009
Thursday, September 03, 2009 - 10:19 am, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That could be it...
A mates missus has a G6E turbo and it hammers but is still very smooth... Another has a r33 and that also goes good and feels faster, different story when the light goes green and the g6e t pulls away easily... Even though the r33 feels faster. Iput it down to the more noise and much harsher ride that gives the illusion of being faster when it's not
UZZ31 V8
Reg: 03-2009
Thursday, September 03, 2009 - 10:33 am, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff Harper - Ummm, "Soarer dude, my soarer is stock and can keep up with my mates 200kw HSV"
Nah we have had a few runs, nothing stupid tho, the last one was both in second gear doing 60 and then flattened and my car began to pull away at about 100kph.
Also I personally think V8 soarer's are quick for the amount they weigh, like the other day, some cool kid in an R33 skyline gtst with a loud blow off valve tried to drag me and then same thing happened, both sitting at 60kph and he put his foot down, so did I and we were side by side until about 90k and then I over took him... I don't know about all this talk sayin V8 soarer's are slow, I reckon they are pretty quick for the weight!
And Andrew, you are exactly right, VP Senator HSV 200kw (at the engine) Red Top motor 5.0i
Sounds beastly!
Ken Yo
V8 SC400
Reg: 08-2009
Thursday, September 03, 2009 - 10:39 am, by:  Ken Yo (Khangz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Regardless, Holdens are crock of crap. Sure its fast but it falls apart.
H oles
O il
L eaks
D ents
E ngine
N oises
Holden = Heaps Of Losers Drive Em Now
Holden = Hundreds Of Little D!ckheads Engineering Nothing
Sorry, I do indeed like the cars don't get me wrong. But too many idiots drive them and think their hard. Same goes for BMW drivers, they all drive like wankers! Ahh, Goooooo's Frabaaa..
UZZ31 V8
Reg: 03-2009
Thursday, September 03, 2009 - 10:43 am, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hahah second that Ken,
Soarer = Perfect Engineering + "Artistic Intelligence"
Oh by the way I was on the freeway when I was with my mate in his Senator and that Skyline tried to drag me.
Even my dad's new Caprice has had problems, that my Soarer have not seen yet haha
David Tra
qld
Reg: 11-2007
Thursday, September 03, 2009 - 12:50 pm, by:  David Tra (Bookie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its fun toying with holdens of that era. I Give them a head start, come second gear and I leap frog over their ass.
Ali Saeed
Thursday, September 03, 2009 - 01:27 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sounds like your ecu needs a reset Jol. while your at it reset your gearbox as well..
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Thursday, September 03, 2009 - 01:48 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've just run a tank full of cleaner through it so yeah i'll do a hard reset tonight (take it off battery for 10 mins)
- frankly I need to compare my car to another uzz31 anyone in melbourne SE wanna pop around for a beer?
Dean Goodwin
Soarer Limited V8
Reg: 08-2007
Thursday, September 03, 2009 - 02:17 pm, by:  Dean Goodwin (Deanno606) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wouldn't mind it, always nice to meet another enthusiast.
UZZ31 V8
Reg: 03-2009
Thursday, September 03, 2009 - 03:24 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew Duaso wrote on Thursday, September 03, 2009 - 10:19 am:
Can't agree with you more about harsher ride and louder gives the illusion of 'fast'.
When I drive my UZZ it doesn't feel 'QUICK!'
but when I look at the speedo, I know it is. Mainly as the smoothness of the ride as well as the sound (mine has stock exhaust ;() takes away that ruggedness the Dirty Datsuns have (Nissans).
James Buchan
UZZ31 V8
Reg: 10-2008
Thursday, September 03, 2009 - 04:39 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good discussion guys, I'm going to get the major service done soon - Timing belt change, water pump etc, and also some new spark plug leads.
Andrew, when you say you've smashed a 185i Stato over & over, is this from a standstill? I find when the soarer is moving they're quick but from a standstill it ain't easy to get them off the line quickly. Maybe I just need a good service. Hehe
Ali Saeed
Thursday, September 03, 2009 - 05:37 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the transmission on the soarer, isnt exactly built to get you of the line quicker is it. its all about the smooth gear changes. get a shift kit and youll spin it going into 2nd.
James Buchan
UZZ31 V8
Reg: 10-2008
Thursday, September 03, 2009 - 05:54 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha I don't doubt that. My tires would not enjoy it one bit. Haha, can't say it's a mod I'll see myself getting anytime soon due to funding! Hehe
Rob Rojo
Soarer TT & UZZ31
Reg: 12-2007
Thursday, September 03, 2009 - 07:27 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If your after a quick car a V8 soarer probably isn't the best choice, they are a great cruiser but unless you spend big $$$ on them they will always be average.
If you want something quick buy a TT soarer and spend around $2000 on mods and it will run mid 12's all day long.
I have raced (at the drags) many Commodores and Fords putting out 300-350rwkw and still beat them most of the time.
Rob Rojo
Soarer TT & UZZ31
Reg: 12-2007
Thursday, September 03, 2009 - 07:31 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ali Saeed wrote on Thursday, September 03, 2009 - 05:37 pm:
I disagree, the Auto Soarer (TT) launches hard 1.6 second 60ft times are pretty quick for a 1600kg 2.5L car.
Andrew Duaso
Reg: 02-2009
Thursday, September 03, 2009 - 08:33 pm, by:  Andrew Duaso (Andrewd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
afaik the TT has a shorter 1st gear ratio and shorter diff gears, the a341e in my soarer has a 2.53 1st and a 3.92 diff vs the a340 tranny with 2.80 1st gear and 4.08 diff
my numbers are off the top of my head so bear with me but you get the point....
now the tranny is a torque multiplier and with shorter 1st gear ratio and shorter diff gearing, the tractive effort of the TT in 1st even without more power than a V8 is still much greater...
Rob Rojo
92 TT & 95 TT
Reg: 12-2007
Thursday, September 03, 2009 - 08:48 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats why a few install the TT diff into the V8's.
Thursday, September 03, 2009 - 08:59 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And some guys install the 1st gear from the TT box into the V8 box :-)
Sebastian Grant
soarer TT
Reg: 01-2008
Thursday, September 03, 2009 - 09:16 pm, by:  Sebastian Grant (Saabg) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think he's referring to the v8, 3.9 diff would get off the line quite slow I'd imagine.
Sebastian Grant
soarer TT
Reg: 01-2008
Thursday, September 03, 2009 - 09:30 pm, by:  Sebastian Grant (Saabg) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And I'm a bit slow to post it would seem...
Thursday, September 03, 2009 - 10:13 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Seb, are you replying to the 2nd post or last post ? LOL ...
Actually the shorter 1st gear ratio would prob make more of a difference than the rear end alone .
3.9 is still a fantastic rear end gear for performance !
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Sunday, September 06, 2009 - 05:24 pm, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
James Buchan wrote on Wednesday, September 02, 2009 - 09:34 pm:
James, a mate of mine has a VS with a supercharged 3.8L motor from a VT Calais, 5 speed manual, 18inch rims and GT gas struts. It would beat my V8 Soarer around town but I think we'd be evenly matched out on an open road.
Supercharged & Intercooled V8
Sunday, September 06, 2009 - 11:08 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is unfortunate my supercharged and intercooled V8 Soarer with well over 300hp @ wheels never made it to the drag strip.
However i do know it held up with VE HSVs quite easily.
