  SoarerCentral * General Soarer Chat * Soarer Tuned 388HP Previous Previous    Next Next
Open in new windowArchive through November 29, 2005Shane Ilich20
Chris Davey
Corona
Tuesday, November 29, 2005 - 11:50 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aah ok. That seems like a conservative figure for those mods. I thought Donnan was claiming 350rwkw or somewhere around there.
Do you have specs on the T04s? I have a Ta45s on mine and would like to compare :-)
Troy Baker
Carnarvon WA
Soarer HKS Single Turbo
Wednesday, November 30, 2005 - 01:04 am, by:  Troy Baker (Sincity) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris I'll get back to you on that tomorrow. I suppose you mean A/ and flow rates. Shane I imagine that your Soarer is making similar power with a 3040 if not more. Be great to see you and your car at the next meet (if I'm in Perth).
Chris Davey
Corona
Wednesday, November 30, 2005 - 01:22 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I would like stuff like wheel diameters, A/'s, inlet and outlet sizes :-)
Shane Ilich
W.A.
Manual Single T
Wednesday, November 30, 2005 - 04:59 pm, by:  Shane Ilich (Ferret) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Troy Baker wrote on Wednesday, November 30, 2005 - 01:04 am:
yeah, but troy - black, and 6-speed getrag....
Troy Baker
Carnarvon WA
Wednesday, November 30, 2005 - 08:17 pm, by:  Troy Baker (Sincity) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris I haven't located the specs yet but I can tell you that it is Flow rated at 550ps and that the inlet is 100mm. It is the HKS version of the old school Garrat T04 with a split pulse outlet.
Troy Baker
Carnarvon WA
Wednesday, November 30, 2005 - 08:18 pm, by:  Troy Baker (Sincity) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh yeh, Martin got 350kw at 1.6 Bar with Elf LeMans race fuel and careful tuning of the Power F/C. $6 a litre but a good increase from 288kw.
Chris Davey
Corona
Thursday, December 01, 2005 - 09:20 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks mate. My turbo has 100mm inlet also and is rated at 650hp. It is the HKS version of the old school ta45 :-) That gives me some hope as my only dyno run so far has made 210rwkw on
PULP@20psi. I have other issues though.
When you get the rest of the specs I would love to compare.
Mine are:
Compressor: 65mm
Compressor A/: .7
Turbine A/: .92
Split pulse t04 flange
4” compressor inlet
3” compressor outlet
4” turbine outlet
Don’t know turbine diameter.
