Saturday, October 31, 2009 - 03:09 pm, by: Shane Sartori(Kingmoron)
I installed a bee*r last nite but its not working properly, once it hits the designated rpm it goes bang/pop whatever but if u put more throttle down, it just goes past the rpm. anyone got any solutions?
also i have an exede chip with is going into NE Cank pos sensor with the bee*r
so far i have Yellow for iGF gren for Ne red for +B and black for E1
Scott Wilkes Goo Roo Tasmania 92 TT Factory Manual
Saturday, October 31, 2009 - 03:13 pm, by: Scott Wilkes(Scottywilkes)
hope you like replacing turbos, ive had 2 mates with 1JZ pop there turbos with the use of the BEE*R due to it being a spark cut, so it causes very large explosions within the exhaust/turbo, and being ceramic, it dosnt take much to shatter them
Friday, November 20, 2009 - 01:06 am, by: Todd Williams(Jza70_r)
my mate and I had a bee*r each, neither of us got it working properly on our 1JZ stock ecu's or a power fc's... figured there was a compatibility issue there with the toyota ignition system...
as for breaking turbos, thats not entirely true, i think if your turbos are in poor health (whether you know it or not) they will break with or without antilag.
i picked a good condition set of turbos 2nd hand, inspected them, thoroughly cleaned them, disconnected oil breathers to them and they have served me well for 2 years with 1.4 bar, launch control (2 step) all the time. search for JZA70 on youtube to see what i mean.
Sunday, December 06, 2009 - 11:45 pm, by: Shane Sartori(Kingmoron)
hah cheers, neighbors think its pretty cool too, they came out to check the fun noises!
its an exede piggyback. i think i have it working ok, in high rpms it will cut back, but low rpms i can just put my foot down and it will rev past it. as i said before i havent tested it under load/in drive
will upload new vid when i have my other exhaust put in (with no cat )
However, i also have a Bee*r rev limiter, that not for the life of me, i can seem to get it working - My supra is a jza70 using a patch harness, so i'm running a jzz30 ecu. I've tried hooking the bee*r up on my friends soarer also with no luck, on the soarer, we have to rev the car, then turn on the gain (thats when it does the bang bang pop) and then cuts out. On the Supra, i have to hook up the the yellow and green on the NE to get it to work - HELP!!!
