  SoarerCentral * Z10/Z20 Soarer Chat * 1JZ Conversion Thread Previous Previous    Next Next
Ryan Pollard
GZ20 Soarer
Reg: 05-2006
Friday, April 13, 2007 - 05:25 pm, by:  Ryan Pollard (Gztwenty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have had my GZ20 (1GGEU) for a year now.
At Christmas 2006 she had a 1JZ-GTE 4Spd Auto dropped in. Had a few troubles so I thought I could post a thread here seeking help on every little upset that happens to it, and also for other conversion owners to post here too.
1. How can i overcome the speedo problem. It's reading only 25% of my actual speed. ie im doing 60km/h and the speedo reads 15km/h (approx).
2. What are the best boost levels for a) the engine, and b) the stock twin turbos.
3. any advice on what to replace, look for, clean, etc etc would be greatly appreciated.
I'm not too cluey on mechanics, but i am learning. I love the GZ20 and i've heard that the ol' 1JZ is better than the RB series of engines. (well, it beats the pants off my old 73rwkw 1GGEU) haha.
Thanks guys (and girls if there are any here)
Christopher Stevens
JZZ20 Soarer TT / SW20 MR2
Reg: 04-2007
Wednesday, April 18, 2007 - 10:50 am, by:  Christopher Stevens (Hamgatan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1. whats the condition of your speedo sensor on the A340E? I got a box recently that had an absolutely f***** speedo sensor. it was cracked and yeah, long story short.. the box got taken back promptly!
2. they can handle 15psi on daily driving reasonably well. why you would want to run that much boost on non-competitive driving is beyond me though.
3. what did you replace on the engine before you did the conversion? did you do it from a straight halfcut cut or engine package?
i'm halfway through this same conversion myself, but yeah i've got a pretty good idea of how its meant to be done..
Ryan Pollard
GZ20 Soarer
Reg: 05-2006
Saturday, April 21, 2007 - 08:48 pm, by:  Ryan Pollard (Gztwenty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1. As far as i know, the speedo condition is fine, just need a 4:1 instead of a 1:1 speed sender gear.
2. 15psi for the turbos yeah? and the engine must be high numbers....?
3. not much replaced. timing belt, water pump. Its out of a JZZ30, only done 52,000ks :-) Bought it as a package from SSS Automotive. JZA70 engine would've been so much less of a hassle, but i didn't know they swapped it for a JZZ30 without me knowing apart from them saying its newer and has 60,000 less ks on it.
4. You know where i can aquire a good radiator for the 1JZ? The 1GGEU just doesn't stay cool. A new GA70 one will cost $440, and a PWR 3 core is approx $700, eeek.
Christopher Stevens
Reg: 04-2007
Monday, April 23, 2007 - 01:03 pm, by:  Christopher Stevens (Hamgatan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
a 4:1 instead of a 1:1 gear? that should ring alarm bells right there. 15km/hr reading instead of 60km/hr reading. 1 x 15 = 15 vs 4 x 15 = 60.
did they use a JZZ30 auto box though? or did they use your existing one and change the bellhousing? the torque converters are completely different between the GZ20 A340 and the JZZ30 A340.
radiator, there are plenty of good ones going around. i know of one or two for sale on Toymods (JZA70 and MA70 ones) that are straight bolt ins with slightly bigger inlet/outlet piping for around the $100-$150 mark. secondhand, but yeah even if you get a radiator recondition its still going to work out under $200.
also make sure you have a decent thermofan setup.
JZZ30 donk should still work alright provided you've used all the stuff from the cut (it would have been cheaper for them to put a JZZ30 cut in than a JZA70 cut by the way because JZZ30 autos fetch about $2200 for a halfcut and JZA70 ones fetch $2800ish)
Andrew Ferres
'86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Monday, April 23, 2007 - 07:08 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are 2 types of Toyota speedo senders.
One is a 4pole, one is a 20pole.
If you use the 4 pole where a 20pole should be, your speedo will read about 20% of normal.
If you use a 20 pole where a 4 pole should be, you speedo will read about 500% of normal.
The UZZ30 uses a 4 pole, so I'd say the JZZ30 uses the same.
The MX83 uses a 20pole, so at a guess the GZ20 does as well.
I'd say you have a 4pole sender in there, and you need a 20pole.
Ryan Pollard
GZ20 Soarer
Reg: 05-2006
Sunday, April 29, 2007 - 02:59 pm, by:  Ryan Pollard (Gztwenty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the speedo help. I'll get around to it one day :-)
As for radiator, I replaced the thermostat the other day, bugger of a spot to put a thermostat!
It heats up, temp gauge goes through the roof, then goes down, jumps around... I think I'm due for a PWR Radiator and to get a compression leak test, also check the temp sensor.
Something is not quite right with the drive train (torque converter maybe). It will rev, I can hear the turbos on low boost, but the power isn't going to the wheels. Then it lunges when the power does go through.... :S
It will get up to scratch one day.
Also, anyone know Z20 or maybe Z30 owners in the Townsville area?
Heng Chau
GZ20 1GGTE
Reg: 12-2006
Thursday, May 10, 2007 - 09:34 am, by:  Heng Chau (Hengsta) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Join toymods mate. and join in with the Z10/Z20 thread in general car talk section and you will find out where they are, think theres a few around in townsville even tho im not from there.
Steven Xue
wa
tt
Reg: 06-2009
Friday, June 05, 2009 - 12:22 pm, by:  Steven Xue (_d_k_) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hello everyone iam new to soarer central i want to do a engines Conversion on my 1988 soarer its a 1G-GTEU and conver it to a 1JZ-GTE 4Spd Auto is there anyone in w.a help me?
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Friday, June 05, 2009 - 12:43 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A guy called Adsport.
Steven Xue
wa
tt
Reg: 06-2009
Saturday, June 06, 2009 - 05:10 pm, by:  Steven Xue (_d_k_) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dose he have a number or something? so how much would it cost for the Conversion? anyone know?
Andrew Ferres
Saturday, June 06, 2009 - 05:21 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://adsportonline.com/
Price wise depends what you want to do.
How fast to you want to spend?
Steven Xue
wa
tt
Reg: 06-2009
Saturday, June 06, 2009 - 05:52 pm, by:  Steven Xue (_d_k_) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
around $2000
Steven Xue
wa
tt
Reg: 06-2009
Saturday, June 06, 2009 - 05:55 pm, by:  Steven Xue (_d_k_) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i just wanna swap the engines
Andrew Ferres
Monday, June 08, 2009 - 02:02 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Unfortunately there is no such thing as 'just swapping engines' when it comes to engine conversions.
David Horley
vic
gz20 v8
Reg: 04-2008
Monday, June 08, 2009 - 04:25 pm, by:  David Horley (V8gz20) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have you signed up with
http://www.z20soarer.org/forums/index.php
there are quite a few guys in wa with 1jz powered z20 s
