  SoarerCentral * Transmission * Penrite Auto Fluid??? Reviews? Previous Previous    Next Next
Ben Evans
"Master Power" Turbo 1J With Xtras
Thursday, January 26, 2006 - 12:27 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know most people use Transmax Z when they have a powerful 1J and its auto, but Penrite have a fully senthetic fluid and its priced $20 cheaper!
Im not sure if its recommended for Toyota boxes, so before i go and throw in $120 worth of fluid, has anyone used it, and whats your thoughts?
I have just got a price for Transmax Z, $65 for 4litres, so if i need 12 litres, thats $200 for just fluid! I know i want my auto to survive this time, but the fluid is as expensive as the bloody auto itself!
Any help would be greatly appreciated. Also, if anyone knows any factory direct type places that i might find it cheaper, let me know :-)
Thanks peoples!
Ben
PS- new auto goes in on the 6th, skylines, supras and porsche's beware
Richard Baird
Perth, WA
Toyota Echo
Thursday, January 26, 2006 - 01:53 pm, by:  Richard Baird (Richo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I get Transmax Z at the best price....
2000 ltr bulk store on tap......LOL
Ben Evans
Thursday, January 26, 2006 - 03:55 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
send me some?
Richard Baird
Perth, WA
Toyota Echo
Thursday, January 26, 2006 - 05:40 pm, by:  Richard Baird (Richo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nope........
Ben Evans
Thursday, January 26, 2006 - 06:06 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well thanks! ahaha
Well this is the info i found about the Penrite ATF fluid (suited to our boxes) and Transmax Z, plus Penzoil synthetic ATF and Mobile Synthetic ATF.
Density at 15 degrees
Penrite = 0.855
Transmax Z = 0.836
Penzoil Syn= 0.878
Mobile Syn = N/A
Viscosity at 100 degrees
Penrite = 7.9
Transmax Z = 7.1
Penzoil Syn= 7.23
Mobile Syn = 7.6
Visocosity Index (lower the number the more it changes from thick to thin when the temp changes)
Penrite = 209
Transmax Z = 170
Penzoil Syn= 182
Mobile Syn = 199
Pour Point Degrees (the lowest temp it can pour in certain conditions)
Penrite = -48
Transmax Z = -60
Penzoil Syn= -57
Mobile Syn = -54
EDIT! WOW! looks like Penrite wins it. and its $20 cheaper!
Transmax seems to be more stable at low temps, but Penrite is more stable through temp changes.
Thanks
Ben
Chris Davey
Corona
Friday, January 27, 2006 - 03:54 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I didn't know anyone used non toyota stuff. I just put toyota type IV in mine. How does that rate? jzx90 chaser box.
Benjamin Burgess
Toyota Soarer GT-TL
Friday, January 27, 2006 - 04:08 pm, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you have a shift kit installed then you use dexron III. If not then use Toyota type IV.
I have MORE Soarers than Hayden :-)
Friday, January 27, 2006 - 04:18 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris,Check your dipstick..I think the JZX90 uses Dex 3..
The 7M Auto uses Type IV
Chris Davey
Corona
Friday, January 27, 2006 - 04:22 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok then.
Is that a shift kit using valve body mods or accumulator mods? I was going to shim the accumulators but have stock valve body.
Currently no shift kit though.
Ben Evans
Friday, January 27, 2006 - 05:07 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
valve body mods, with the spring or copper pipe :-)
