"Well I finally fixed the dreaded leaking power steering pump and stuffed alternator. I'll give you all some more de3tails when I have time. Basically I just bought a P/S rebuild kit from Brighton lexus for $49 (less at Melb city) and new Bearings from SKF bearings for $22. The hardest bit was the alternator. In the end I found out the rotor was the same as the landcruiser 100series V8. I found a great place who rebuild the rotors. Cost me $75 changeover on a rotor. I then got the new bearings (a little bit harder to get as they are japanese specials) from the Bearing Warehouse for $20. I was going to replace the brushes but got the wrong ones and basiclly needed it fixed by the weekend. The old ones looked ok. Anyway, all fixed and back on the road for less than $200! I'll post all the part no. etc later as it should save you some time. Hope I can help you guys as I found it hard to gather the info."
