  SoarerCentral * Air Conditioning and Climate Control * Sport air filter and hot engine air Previous Previous    Next Next
Tazo Chitidze
georgia
2.5 turbo
Reg: 12-2010
Thursday, April 19, 2012 - 06:02 pm, by:  Tazo Chitidze (Tazo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i change my stock air filter with aem dry flow sport air filter.but after 10 minutes air filter is warm with engine's hot air & it influence on horse power?
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Thursday, April 19, 2012 - 06:50 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, hot air will reduce performance. You need to build a box around the filter and feed it with cold fresh air.
Tazo Chitidze
georgia
2.5 turbo
Reg: 12-2010
Thursday, April 19, 2012 - 08:39 pm, by:  Tazo Chitidze (Tazo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there is small place for box
Orton Marchant
NSW Blacktown
Reg: 01-2011
Thursday, April 19, 2012 - 10:59 pm, by:  Orton Marchant (Mythorite) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
try and feed it into your bumper maybe for straight cold air? and you prob wont have to build a box.
DAMMMMMM THAT IS HUGE!!!!
Kurt Atzmuller
TT`s
Reg: 05-2011
Friday, April 20, 2012 - 06:03 pm, by:  Kurt Atzmuller (Kurt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looking at these single turbo 1j's i reckon there just might be a good intake set waiting to happen for these!!
That standard setup still looks almost like there's twins in there!
Definitely try and box it in though, pod sits in there nicely Tazo.
Tazo Chitidze
georgia
2.5 turbo
Reg: 12-2010
Tuesday, April 24, 2012 - 08:56 pm, by:  Tazo Chitidze (Tazo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks kurt & norton
