  SoarerCentral * Track and Major Rebuild Car Projects * Green UZZ31 Build... Previous Previous    Next Next
Allan Langford
Reg: 05-2010
Wednesday, September 11, 2013 - 11:42 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thought I would start a new build thread for my "new" older 91 Soarer now that the Black car has gone to it's new home...
Picked this one up with a dead diff for cheap...
Allan Langford
Reg: 05-2010
Wednesday, September 11, 2013 - 11:50 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Planned Modifications..
Motec M800
PCS TCM2000 Transmission controller
Ford Motorsport TVS2300 Supercharger with Drive by wire throttle
Bullet Intake modified with Laminova intercooler cores
Koni Yellow shocks with oem air bags cut off old struts modified and refitted
Whiteline sway bars
Maltech Brake lines
Supra 4pot front 2 pot rear (DBA 5000 front 4000 rear)
Nitto Invo 275/35R18 on HR 109's all round
96+ Tail lights
and probably more... ;)
Allan Langford
Reg: 05-2010
Wednesday, September 11, 2013 - 12:05 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Supercharger:
Laminova intercooler cores:
Koni's:
Aaron Casey
'94 2jz JZZ30 gttl, '93 UZZ31 track, VT, 2x Leyland Mini's
Wednesday, September 11, 2013 - 01:15 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Niiice! Sounds like it will be a great street car :-)
John Street
Calais V 6.0ltr
Wednesday, September 11, 2013 - 04:42 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Allan,
Do you have a tute that you might like to share re replacing the shocks within the airbags? Just asking
Allan Langford
Reg: 05-2010
Wednesday, September 11, 2013 - 11:09 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have not done it yet, I'll take some photo's when I do
BMW E36 Coupe 1UZFE V8 340i
Thursday, September 12, 2013 - 08:03 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Awesome Allan.
That is a really nice looking Soarer you have there.
The perfect mod list too.
Oleg Akulshin
V8 UZZ31 8PSI of BOOOOST
Reg: 06-2009
Thursday, September 12, 2013 - 10:52 am, by:  Oleg Akulshin (Sliqu3) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Really looking forward to that Laminova core being installed. Is it going to fit straight into bullet manifold? or will it require a raised adapter plate? If its not too complicated I might give that a shot over water meth injection.
Allan Langford
Reg: 05-2010
Thursday, September 12, 2013 - 11:09 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oleg: going to require ALOT of stuffing around and modifying the bullet manifold to keep it all below the bonnet!
hows your blower going?
James Buchan
vvt-i turbo
Reg: 10-2008
Sunday, September 28, 2014 - 04:30 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How did I miss this thread? Did you sell your black V8 Allan - it had the Eaton 112 on it from memory? This the new project eh?
