Author |
Message |
Scott Vim
DieHard Vic Soarer (1uz) Chaser (1jz)
Posts: 997 Reg: 12-2010
Scott Vim
Posts: 998 Reg: 12-2010
Scott Vim
Posts: 999 Reg: 12-2010
| I marked it with a pen where the line is. I'm not sure how obvious it's going to be if its out by one tooth but to me it looked OK. I will check other side tomorrow. |
Scott Vim
Posts: 1000 Reg: 12-2010
Dave Rose
Goo Roo wa UZZ31 / ML320 CDI
Posts: 2502 Reg: 03-2007
| only turn engine the way it runs, move up to the crank timing mark then stop now check rotors (do not turn back to line up if you miss the mark) just start again .its all to do with the tension on the belt. good luck. |
Scott Vim
Goo Roo Vic Soarer (1uz) Chaser (1jz)
Posts: 1001 Reg: 12-2010
| That's TDC in my first pic right? And the second is the rotor on the line. Should I go around again? |
Tom Richards
Goo Roo nsw V8
Posts: 1942 Reg: 08-2005
| check them both at the same time, that one looks ok. |
Dave Rose
Posts: 2503 Reg: 03-2007
| As long as you only turn engine the way it runs (clock wise} to the crank mark then check rotors you will be correct , as Tom says do it a couple of times . |
Scott Vim
Posts: 1002 Reg: 12-2010
| Yep turning the crank the right way. So if its out it should be obvious. OK will check otherwise tomorrow and give it another turn back to TDC. |
Robert Day
DieHard victoria v8 & TT
Posts: 780 Reg: 01-2007
| If you do go past the timing marks as you are winding it over, you can turn it back slowly but you need to go back WAY past the marks by 30 - 45 degrees or so & then come up to the marks again which by that stage will have the correct tension on the drive side of the Cam Belt & so wont give you a false reading .. |
Scott Vim
Posts: 1003 Reg: 12-2010
| Yep no problems just to keep things simple I'll just turn it one way to make sure no mistake is made. I'm guessing if its off it will be off by at least 45 degrees? Or is one tooth going to be 10 degrees. That might not be so easy to see. Just in case it looks OK to me but isn't I'll post pics here. |
Jamie Richards
TryHard St.john's v8
Posts: 223 Reg: 06-2009
| Just make sure bottom mark is on 0 then check top marks, then you will know for sure |
Dave Rose
Posts: 2505 Reg: 03-2007
| if its out you will see it on the rotors , not crank that has to stay on TDC o . |
Robert Day
Posts: 781 Reg: 01-2007
| As has been said, just make sure the crankshaft pulley is on 0 degrees & only worry about that as you are turning the motor over & the cams will be either spot on or out & if out by 1 tooth only it is probably more likely to be around the 5 - 10 degree mark .. And just to confirm it, you are turning the crank pulley clock wise I hope .. And the reason i mentioned that you can turn the crank back is if you over shoot the crank mark you then have to turn the crankshaft 720 degrees, 2 complete rotations of the crank to get the camshaft's lined up again, your call on what you end up doing .. ( but if you wind it back you have to go way back past the mark & then come forward slowly again ) .. |
Scott Vim
Posts: 1005 Reg: 12-2010
| Yep clockwise. So if I go another 360 degrees it will be completely off? Yeah I know the crank must be set to 0 as a reference point. So two full rotations equals one cycle of the motor. Think I get it. I'll do it first thing in the morning. |
Robert Day
Posts: 782 Reg: 01-2007
| The camshafts turn at half the speed of the crankshaft, so the crankshaft needs a full 720 degrees rotation to make the cams rotate 360 degrees & so back to the timing marks .. I could explain a lot more but I don't think it's going to help you much for now .. |
Scott Vim
Posts: 1007 Reg: 12-2010
Scott Vim
Posts: 1008 Reg: 12-2010
| OK guys did a full 2 rotations to get back to TDC again. It looks pretty right. Maybe slightly out but its hard to say |
Tom Richards
Goo Roo nsw V8
Posts: 1943 Reg: 08-2005
| at TDC, are both rotors "pointing at the mark" on the disti body? If not, pull the belt 1 tooth, looking at the disti and see if it now lines up. The photo above does not appear to line up. |
Scott Vim
Posts: 1009 Reg: 12-2010
John Street
TryHard NSW VE Calais V8, 2009 Saab 9-3 Turbo
Posts: 460 Reg: 08-2005
| Scott, put a mirror dead in front of your dizzie then photograph the image, from the angle of the photo you have posted impossible to tell if its right or not |
Scott Vim
Posts: 1010 Reg: 12-2010
Scott Vim
Posts: 1011 Reg: 12-2010
| The mirror is a good idea I won't be able to do that until later tonight or tomorrow. To me both of them look out by about 5-10mm. Its hard to judge though. Best get the mirror and show you guys but its not what I would call spot on the mark. |
John Street
Posts: 461 Reg: 08-2005
| That one is good what about the other one ? |
Scott Vim
Posts: 1012 Reg: 12-2010
 As above looks slightly off. Both of them. Would it even run having both of them off like this? I doesn't run that bad just won't rev out. Once its warm it runs pretty good under the 3k mark. |
