  SoarerCentral * Parts For Sale * Wrecking 31 limited Previous Previous    Next Next
John Stafford
Qld.
Titanium Territory, Petrol 7 seater, GC8 WRX STI, 2010 WRX
Reg: 02-2010
Friday, July 06, 2018 - 10:12 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have sold my 2 soarers and now need to move this spare parts car on. The end of a most memorable era. Many times of enjoyment but moving on.
I have a white 31 that is missing an engine and gearbox and an assortment of parts but still have a lot left including the following, but not limited to these parts. I am open to offers on anything as I want to shift as much as possible before dumping the shell.
Don't be shy to make an offer on anything. I very flexible on some items and more reserved on others. I do need to clear the car and the shed.
Good climate control from 1JZ $130
Special front lower control arms with perfect Vlamos rubber bushes and new replaceable Lexus ball joints. These arms will last forever (perfect) cheap at $900.
Rays volks 3 piece racing wheels 9" fronts with michelin sport 3 rubber, still legal depth, rears are 9 1/2" with Achilles tires worn down to 1 mil inside but heaps of tread left over the whole tire. These wheels are like new and the rims cost over $5000 new. $1900 the lot.
Brand new top quality braided front brake lines $70.
Tan front cup holder $40.
V8 Air con compressor $40.
V8 Full exhaust $60, with original headers $80.
V8 limited 1992 Non-working EMV touchscreen (reduced to $20).
V8 limited Left hand front leather power seat in good condition $50.
V8 limited Right hand front leather seat needs re-leathering. The forward and reverse action has stopped working. Buy it for spare parts or to fix $30 (worth that for the motors).
Left hand door-card, repaired and strengthened $120).
$170 with all the accessories like handles, wood trim and window controls.
Driver's side electric control ($50)
Passenger's side window control ($20)
Internal door handles $40 each.
V8 Power steering pressure hose from pump to rack ($50).
V8 Radiator, brand new replacement only a few months before the thermo housing failed on the engine $100.
"Limited" front mudguard badges $10 each.
"Soarer" rear badge $20
Toyota bulls horns boot badge $15.
1991 rear tail lights. I have 2 right hand and 1 left hand at $30 each light.
1 set of rear '94 tail lights in mint condition $150
Headlights. R/H $25 L/H $40.
One set (R/H and L/H) both with HID bulbs and balasts $65 each.
One set of front lights in mint condition ($120).
High beam lights $20 each (plastic).
Near new Walbro 255 fuel pump available $50.
V8 Hydraulic fan assembly $80.
V8 3x40 pin Non working engine ECU $10.
New hand brake cover (spruce) $15.
V8 IACV (Idle control valves) x 1 '96 type and 1 '91 type, guaranteed perfect working order $90 each.
Tan Steering wheel. It needs re-leathering but comes with a steering wheel cover $10.
Window surrounds $20 each (cracks repaired but need pick up).
V8 Brakes, front $20 the pair.
Rear V8 brakes $20 the pair.
Front wheel bearing hubs $20 each.
Good condition steering rack with new bushes and good boots $100
Brand new 2 piece aftermarket spruce complete floor carpet that needs plastic sides repositioning to get a good fit (Quite do-able) ($30, it cost quite a bit more than that).
Front tan (resprayed) genuine Soarer floor mats $40.
Rear seat belts $20 each.
Fuel pump (Standard Toyota pump) $15.
V8 Air-flow meter assembly $100.
V8 Throttle body $80
V8 Alternator Belt tensioner $40
2 used V8 accessories belts $10 each.
Airbox $20
V8 Master cylinder (2 outlets) $40
V8 Brake booster $40
V8 ABS unit $40
Front Upper control arms $20 each.
Just MAKE OFFERS ON THE FOLLOWING.
Stablizer bars.
Rear suspension components, links etc.
Internal trim pieces (tan) like the console and steering surrounds etc.
White Panels (doors, boot, bonnet and anything else you want, like front and rear bars. Various condition.
Window winder motors (pull them out yourself).
Hub caps for 15 inch classic soarer mags.
Various V8 limited ecu's, like air con, door controls etc.
Non working CD stackers ($10 each)
I have 2 failed V8 fuel ecu's for free if you want them to attempt repairs.
The whole car has to go. Any shell parts are up for sale, everything.
Feel free to ask about any other parts you may need, or to make an offer on anything or to get a special price for bulk parts buy.
Tai Johnsen
JZZ30 Pov Manual LSD & black! + 89 Z20 Aerocabin
Friday, July 06, 2018 - 10:32 am, by:  Tai Johnsen (Privatejohnsen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sad to see you go John.
All the best with the clear out.
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Friday, July 06, 2018 - 10:42 am, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi John.
Is the emv complete, or just the touchscreen? I'll take it if complete & you'll post ( at my expense of course)
Tim Schroeter
V8, V8, V8, V8
Reg: 04-2014
Friday, July 06, 2018 - 10:48 am, by:  Tim Schroeter (790) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I should have read the add fully. Ill take the engine ecu & cd stackers, if you can get a quote on post for the latter to 2640. Cheers.
Roland Elliott
uzz32 1uz-fe
Reg: 08-2014
Friday, July 06, 2018 - 10:49 am, by:  Roland Elliott (Aussie2013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have sent you an email john , with a list.
Mark Tierney
JZZ30 GTTL 446rwkw, GS350 F-Sport, UCF11, Supersport
Friday, July 06, 2018 - 03:03 pm, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Email sent John
John Stafford
Qld.
Reg: 02-2010
Friday, July 06, 2018 - 04:22 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Tai.
EMV is total with wood grain. I also have wood grain ash tray part and gear stick surround it you like for another $15. Waiting to hear back from Tim re ok to post.
Seat will be pick up only as they are so heavy.
I also have a power steering pump (use your own pully). Good except it needs the top "O" ring when you fit that top piece to it upon fitting to the car $50.
Jack Driver
vic
Reg: 08-2010
Saturday, July 14, 2018 - 07:02 pm, by:  Jack Driver (Jacko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey John
I'll take the good steering rack with boots, the new aftermarket spruce carpet and the steering pump.
How much to Ego courier to 3182?
Thanks.
John Stafford
Qld.
Reg: 02-2010
Saturday, July 14, 2018 - 07:55 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Jack, I sold the rack to Mark Tierney on this page. Not sure if he actually needs a V8 one. He thought that it was from a J30. Ask Mark if he wants to onsell it or if he is keeping it?
I will pack up the carpet and the pump on Monday and let you know the postage.
Cheers John
John Stafford
Qld.
Reg: 02-2010
Tuesday, July 17, 2018 - 07:19 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here are the figures on the Rays wheels:
Rims and tires. These are deep dish excellent condition, very low kilometers traveled. They are quite rare design and very strong 3 piece construction. They coast over $5000 new. The fronts are 18 inch with 45 profile rubber and the rears are 19 inch with 30 profile. This means that the outer diameter of the tires front and back are the same but the heat transfer on the back is catered for with the larger rim size and lower profile tires. These are great rims.
Fronts are 9" running 235s and have 35 offset and rears are 9 1/2" running 265s and have 27 offset. Get a bargain.
The perfect front and rear lights have gone but still have good ones with HIDs left for the front and rear 91 lights.
EMV and ECU and CD stacker gone.
Steering rack and power steering pump gone
but
lots of other stuff left, including LH door card and window trims etc. Get those trim pieces that you were thinking of replacing in tan.
Come and have a look and make me an offer.
Pick up needed for the front seats.
John Stafford
Qld.
Reg: 02-2010
Thursday, August 09, 2018 - 09:05 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Re post of what I have now with some price reductions:
Don't be shy to make an offer on anything. I am very flexible on some items and more reserved on others. I do need to clear the car and the shed.
Good climate control from 1JZ $100
Special front lower control arms with perfect Vlamos rubber bushes and new replaceable Lexus ball joints. These arms will last forever (perfect) Very cheap and irreplaceable at $800.
Rays volks 3 piece racing wheels 9" fronts with michelin sport 3 rubber, still legal depth, rears are 9 1/2" with Achilles tires worn down to 1 mil inside but heaps of tread left over the whole tire. These wheels are like new and the rims cost over $5000 new. An absolute bargain at $1900 the lot.
V8 Air con compressor $30.
Original headers $80.
V8 limited Left hand front leather power seat in good condition $50 Pick up only!
V8 limited Right hand front leather seat needs re-leathering. The forward and reverse action has stopped working. Buy it for spare parts or to fix $20 (worth that for the motors) pick up only!
Left hand door-card, repaired and strengthened $110).
Left hand door card with all the accessories like handles, wood trim and window controls $150.
Driver's side electric control ($40)
Internal door handles $30 each.
V8 Radiator, brand new replacement only a few months before the thermo housing failed on the engine $80.
"Soarer" rear badge $15
One set (R/H and L/H) headlights, both with HID bulbs and ballasts $50 each.
V8 Hydraulic fan assembly $50.
V8 IACV (Idle control valves) x 1 '96 type guaranteed perfect working order $90.
Airbox $20
V8 ABS unit $40
Internal trim pieces (tan) like the console and steering surrounds, window surrounds, hood lining etc. from $10 plus postage and handling.
Front bar indicator lights $15 each.
Front turning lights $20 each.
Stablizer bars.
Special rear number plate frame.
John Stafford
Qld.
Reg: 02-2010
Sunday, August 12, 2018 - 07:06 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Update list, some prices dropped and some things added and some sold.
I have lowered some prices. Ask about items that you might need but which are not listed.
Special front lower control arms with perfect Vlamos rubber bushes and new replaceable Lexus ball joints. These arms will last forever (perfect) Very cheap and irreplaceable at $800. (New ones are about this price landed from the U.S. for one, not two, (look on ebay for SC400) and they do not have replaceable ball joints, which is a huge thing as this is a problem with old arms.
High beam lights, 2 sets $20 each light (plastic).
Toyota plug lead set, all tested within spec. $40 for the set.
Brand new central steering rack bush (super pro) $10
Perfect condition electronic rear view mirror (Very rare to get a good one) $100
Airbox $20
V8 ABS unit $40
Tan glove box in great condition $25.
Internal trim pieces (tan) like the console and steering surrounds, window surrounds, roof lining etc. from $10 plus postage and handling.
Original headers $20.
Stablizer bars.
Special hinged rear number plate frame.
Dan Newton
JZZ30 VVTi
Reg: 09-2015
Wednesday, August 22, 2018 - 06:46 pm, by:  Dan Newton (Danbad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi John, I'll take the climate control. I'm in Brisbane but won't be available until the weekend. You're in QLD right?
Philip Bryant
UZZ30 V8
Reg: 12-2016
Tuesday, October 23, 2018 - 08:41 am, by:  Philip Bryant (Levinte27) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do you still have the climate control unit?
John Stafford
Qld.
Reg: 02-2010
Tuesday, October 23, 2018 - 01:27 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, still have it. Ring me on 040175908
Yes, it is still here.
John Stafford
Qld.
Reg: 02-2010
Tuesday, October 23, 2018 - 01:28 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
that is a wrong phone number, try 0401759098
