  SoarerCentral * General Soarer Chat * Antenna Previous Previous    Next Next
Alfred Heng
NA
Sunday, February 19, 2006 - 10:13 am, by:  Alfred Heng (Alfred) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does the Soarer come with an antenna built into the glass or does it have one of the extending wands? I have seen cars that look like there is no antenna and some with an automatic extend wand on the rear fender.
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Sunday, February 19, 2006 - 10:14 am, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
external was only on the US spec SC's.
Jap models were on the glass
Ben Socratous
Sunday, February 19, 2006 - 02:29 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone else find that the antenna on the glass is just not up to scratch compared to an external? I nearly lose all reception as soon as I drive past a tall tree, building, sugar ant... Oh well, guess that's why they invented empyfreez!
Dave Hart
Waikato
UZZ32
Sunday, February 19, 2006 - 03:24 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fairly crap over here as well Ben.
Sunday, February 19, 2006 - 05:22 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Excellent here. I am using Vlad's conversion rather than expanders. I believe it exploits both antennae.
Mark Paddick
Soarer UZZ31
Sunday, February 19, 2006 - 07:15 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Expanders are useless. It is those that affect your reception not the antennae. A Vlad converted radio has reception at least as good as any other car. Metallic tint on the window will affect reception too.
If you don't have EMV then you can't do Vlad's mod but you CAN get a US spec Lexus head unit with correct FM band (bur wrong AM).
Norfolk Island
Sunday, February 19, 2006 - 08:04 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I took the4 expander off our Soarer, as Mark says, they are useless. Luckily local radio here is 89.9MHz. Reception's good without the expander.
The Wizard has aftermarket 2DIN stereo with only one aerial connected- they are both in the rear quarter windows. I lose reception every time I go into a hollow.
Monday, February 20, 2006 - 12:55 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Some guy in Victoria developed a technique of cutting a line in the metallic foil tint that caused it to not mess with the reception. If I can find any more info, I will post it up.
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Monday, February 20, 2006 - 07:48 am, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i just used a non metallic tint on the back glass.....it's what they do with the BA Falcons too...
Ryan Mason
Soarer TT-L
Reg: 01-2006
Monday, February 20, 2006 - 10:55 am, by:  Ryan Mason (Ryan_m) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That is exactly right, Most Tint guys with any kind of a clue will know you can't use a metallic rear tint when the car in question has a rear glassed antenna.
I got metallic on the sides, but non metallic on the back, and it works beautifully. :-) Looks hot as hell too.
Monday, February 20, 2006 - 11:19 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What brand of non-metal tint do you guys use?
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Monday, February 20, 2006 - 11:28 am, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dont know... was done at AM Glass tinting in Geelong.. 20% tint on rear...
Monday, February 20, 2006 - 12:28 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Might do some research then. Last I checked, it seemed the non-metallic ones pretty much all faded after a while. Then I see those horrible purple tints that have bubbled and it puts me right off. :-)
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Monday, February 20, 2006 - 12:31 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah..he said it wont last as long as the metallic, but will last for quite some years :-) is a slightly different colour too looking at it from the inside, but from outside you would never pick it
Monday, February 20, 2006 - 04:14 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob Andreacchio wrote on Monday, February 20, 2006 - 12:31 pm:
That's because if ya wanna "Pick it", ya can only do it from the inside, coz that's where they stick it, Yeah!
Know what I mean chook
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Monday, February 20, 2006 - 04:37 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is it Friday already??? hahaha
Mark Paddick
Soarer UZZ31
Monday, February 20, 2006 - 04:53 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nah...but it feels like it should be
Monday, February 20, 2006 - 04:59 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It bloody should be, after the day I've had!
But Hey, it's nuttin a few Bourby's won't fix
Steve Latimer
UZZ32
Monday, February 20, 2006 - 09:09 pm, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, Cheers Donno......
