Author |
Message |
Mike Bradberry
TryHard Queensland V8 Limited
Posts: 150 Reg: 07-2005
| I always have my Limited in 'power' mode, but have tried the other switchable position and I'm damned if I can feel any difference. Am I expecting too much or maybe the switch isn't working. Any thoughts? |
Jan Christiansson
TryHard NSW Soarer V8
Posts: 130 Reg: 07-2005
| You don't get more power out to have the switch on, it just holding the gear for longer time when you floor it. |
Mike Bradberry
Posts: 151 Reg: 07-2005
| Thanks Jan, I didn't make myself clear. What I wanted to know was the difference in the change points. |
DieHard Victoria UZZ-32 V8 Soarer #138
Posts: 932 Reg: 07-2005
| Do a search, It is on here somewhere. |
Junk Filterer South Australia GT4.0 V8
Posts: 3801 Reg: 11-2004
| Vewwy widdle. Said the rabbit. |
Benjamin Burgess
TryHard NSW Toyota Soarer GT-TL
Posts: 354 Reg: 07-2005
| I'm pretty certain power mode keeps the torque convertor mechanically unlocked for much longer as well. Makes your fuel economy go to s***. |
Goo Roo ACT Soarer UZZ31 V8 manual. Lexus IS300
Posts: 1682 Reg: 07-2005
| In my experience, if you floor it then the two modes will behave exactly the same. The Power switch makes a difference to partial throttle gear changes, holding longer or changing down earlier. I have found very little difference in fuel economy in normal driving. |
Sam Schreck
DieHard ACT vvt-i JZZ31
Posts: 653 Reg: 07-2005
| Mine makes a huge difference. In power mode it'll easily rev to redline very quickly and hold there for a little bit, and loves it. In normal mode flooring it it'll usually rev till around 5 - 51/2 and shift up a gear very quickly. Power mode scares me. I tend to cringe a bit when I hear the engine working that hard even though it probably loves it. And yes, the fuel gets gulped big time. |
Posts: 1684 Reg: 07-2005
quote:And yes, the fuel gets gulped big time
Probably something to do with 5500 RPM  |
Sam Schreck
Posts: 654 Reg: 07-2005
| More likely 6200 RPM POWER MODE!!! |
Goo Roo Melbourne Soarer TT
Posts: 1288 Reg: 07-2005
| Or 7200rpm's in a TT! |
Avin Luther
DieHard vic Soarer uzz31 Limited
Posts: 903 Reg: 07-2005
| or 9000 in an S2000 |
Posts: 942 Reg: 07-2005
| Or 19 000 in a F1 |
Posts: 943 Reg: 07-2005
| Or 47 000 in a jet turbine engine. |
DieHard WA Soarer TT
Posts: 819 Reg: 09-2005
| Or 100,000,000 in a bunny rabbit's bed. ;) |
DieHard North Island 3.0 GT
Posts: 577 Reg: 10-2005
Morgan Cross wrote on Thursday, March 23, 2006 - 08:56 pm:Or 7200rpm's in a TT!
Hmm, how fast do you recon your turbo turbine would be spinning at that many RPM? |
Emanuel Spinola
Moderator NSW JZZ30, UZZ32
Posts: 727 Reg: 07-2005
Matthew Sharpe wrote on Friday, March 24, 2006 - 07:29 am:Hmm, how fast do you recon your turbo turbine would be spinning at that many RPM?
The same speed as if the engine was doing 3000rpm - the wastegate(s) bleed(s) excess boost from low in the rpm range. Turbine shaft and crankshaft rpms are not directly proportional. My 1JZ-GTE would rev happily/regularly to it's 8500rpm hard redline - you get that with the 1JZ-GTE's ideal bore/stroke ratio. |
Posts: 954 Reg: 07-2005
| I think the turbo's normally spin around the 80-90 000 rpm mark. |
Posts: 1297 Reg: 07-2005
Avin Luther wrote on Thursday, March 23, 2006 - 09:47 pm:or 9000 in an S2000
Haha, beaten by a 4 banger... :P |
Posts: 578 Reg: 10-2005
| I thought the wastegate was placed after the turbine? So the exhaust gasses pass through the impeller at a rate dependent on engine RPM's, driving the turbine to produce the boost, which is then bled off by the wategate if the boost is too great (thus the impeller and turbine speed would be releated to engine revs/amount of exhaust gass released) - not that I claim to know anything about turbo's as I've never owned or worked on a turboed car...  |
Luke Middleton
Tinkerer NSW V8 Limited
Posts: 75 Reg: 07-2005
| The wastegate is used to bypass exhaust gas from going through the turbine thus controlling the turbine speed.That's the way I understand it anyway. |
Posts: 579 Reg: 10-2005
| I guess that would help keep friction temperature and wear down, so it does make sense. |
Mark Paddick
Goo Roo ACT V8 Soarer UZZ31, JZZ30 TT Soarer I'm catching up!
Posts: 2149 Reg: 07-2005
MiNe(s) is 8500rpm Misses real bad up there though...new plugs required. At least there's only 6. |
