  SoarerCentral * Bodywork and Exterior * Fitting '97 Fogs? Previous Previous    Next Next
94 UZZ31 (V8) / 96 JZZ30 (TT)
Tuesday, April 18, 2006 - 12:46 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys. Since I have the Vertex front bar on my '96 TT, I really dislike the amount of empty holes left behind. I'm going to buy the '97 foglights but will they be straight plug and play? Or do I need to purchase the wiring loom? Hope someone can shed some light on this.
Will Adams
Soarer GT-TL
Tuesday, April 18, 2006 - 12:57 pm, by:  Will Adams (Draco) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vinh, if I'm right your TT should just have the wiring to allow plug and play (someone correct me if I'm wrong). From what I understand late 94 Soarers were converted to fog lamps and not turning lamps as per pre-94 Soarers.
Tuesday, April 18, 2006 - 10:20 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Will, yes I'm aware that 94+ cars came with foglights. What I'm trying to find out is whether the existing connector will plug straight into the '97 foglights, or will I need to replace the existing plugs with something that WILL be compatible with the foglights. Thanks anyway Will.
