  SoarerCentral * Bodywork and Exterior * Rear Bar removal Previous Previous    Next Next
Dave Storrie
91JZZ30 TT For Sale, 95 JZZ30 TT
Reg: 12-2005
Thursday, April 20, 2006 - 05:32 pm, by:  Dave Storrie (Casp3r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Afternoon guys,
I'm in the process of removing the rear bar, pulled out the lights and all the scrivets above and below, 2 screws on the bottom of the bar each side also removed. One problem but, there seems to be some screws or scrivets down the sides of the bar that look almost like the rear quarter panels need to be removed to get to :o Just needing some help, did a quick search and found plenty on removing front bar but not on rear :\
Any help appreciated, cheers!
Haydn Crandell
TT 2.5
Thursday, April 20, 2006 - 07:12 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
isnt there 3 nuts inside the boot where the bar meets the quarter panel? just undo them ,take the trim out they are in there.
Avin Luther
vic
Soarer uzz31 Limited
Thursday, April 20, 2006 - 09:58 pm, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you have to get right down the bottom of the boot. there is a black box on either side (They are vents to release air pressure when you slam the boot shut, one beneath the jack compartment, and one under the stacker side) that have to be taken out to get to the very bottom screws. It CAN be done from inside the boot, you just ahve to move the linings and a bit of stuff to get to them.
Dave Storrie
Reg: 12-2005
Friday, April 21, 2006 - 12:29 pm, by:  Dave Storrie (Casp3r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found them, thanks for the help!
