  SoarerCentral * General Soarer Chat * Immobiliser Previous Previous    Next Next
Saturday, April 22, 2006 - 01:21 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have run a search but found nothing.
Probably a dumb question. I just picked up my new 91 Soarer and want to know if it has an immobiliser in it?
Ben Socratous
JZZ30 GT-TL
Saturday, April 22, 2006 - 07:22 am, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do you have keyless entry? Most immobilsers/alarms are rigged up to some kind of keyless entry system. Simple test, don't touch anything and try and start the car. If it start's probably not!
Michael O'Driscoll
Saturday, April 22, 2006 - 09:46 am, by:  Michael O'Driscoll (Remickz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And if alarms go off, and the car wont start, then you probably have an alarm/immobiliser.
Good luck
Saturday, April 22, 2006 - 10:10 am, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I dont have an alarm yet.
I dont have keyless entry.
I put the key in the ignition and it starts up.
hrmmm.
Phil Gibson
'94 black/black UZZ31
Saturday, April 22, 2006 - 01:12 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you dont have an alarm (and presumably you want one) give Shaun from Distinctive Car Imports a call 0402 841 941
He fitted my alarm, knows Soarer wiring inside out and will do a good job
Saturday, April 22, 2006 - 05:53 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll vouch for that =P
..although im still waiting to see his fancy alarm system so i can determine if i want to copy or not.. >=\
Sunday, April 23, 2006 - 04:18 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I tried him on sat and today and he is still unavailable ...
I need an alarm with immob. etc.
Sunday, April 23, 2006 - 09:12 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah they were flat out on Sat, mainly driving me all around Wangara >.>
DCI arent open on sunday though? ;)
They usually close at midday on sat as well.. >.>
Sunday, April 23, 2006 - 10:10 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In the meantime, do u know if he installs Laserline system alarms ?
I have been calling around and if DCI can do it cheaper, that would be great.
Monday, April 24, 2006 - 12:20 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not sure, but Shaun will be able to tell you what to use, and he should be able to source + install.
Monday, April 24, 2006 - 01:53 pm, by:  Adam Peterson (President) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its booked in with Shaun for this sat :-)
Monday, April 24, 2006 - 08:20 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
SOFB! Hes never going to rewire mine at this rate ='(
Bill Bogiatzis
Saturday, April 29, 2006 - 01:54 am, by:  Bill Bogiatzis (Boggie23) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
guys what would be a place in sydney.
Shaun will be all good and fancy for you WA boys but what about me..... It isnt fair.... I cant drive all the way there just to get a alarm cant you see.
