  SoarerCentral * Transmission * Gear box oil for manual tt Previous Previous    Next Next
Joshua Maynard
Wednesday, December 21, 2005 - 03:43 pm, by:  Joshua Maynard (Joshzilla) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey what type of oil's should i put in my manual tt soarer gearbox to stop the bit of bumpand grind thats going on.... im gettin marlew performance to give my car a bit of a service and we need the name of the good stuff to get.. cheers all
Joshua
Karim Tabbouch
Soarer JZZ30 ..Single Turbo ..Manual : )
Wednesday, December 21, 2005 - 05:15 pm, by:  Karim Tabbouch (Count) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
redline ....lightweight
Brad Elphinstone
JZZ30 GT-T
Wednesday, December 21, 2005 - 07:09 pm, by:  Brad Elphinstone (Belphins) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yup. Some redline will make for smoother gear changes.
Justin Camilleri
1985 MZ10, 1992 TT, 1991 TT
Sunday, January 01, 2006 - 03:16 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does this work on autos as well?
Simon Triantafillou
Soarer Turbo
Sunday, January 01, 2006 - 10:11 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Justin, manual and automatics use quite different oil specifications. The Redline will not work properly in an automatic transmission.
Josh Rafton
TT manual
Monday, January 02, 2006 - 05:02 pm, by:  Josh Rafton (5tyl5h) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Red line MTL or MT90
Shane Ilich
W.A.
Manual Single T
Tuesday, January 03, 2006 - 01:27 am, by:  Shane Ilich (Ferret) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah - i've got a w58 (now that i've just about finished the manual conversion) - which oil is best for it? redline MTL, MT90, or lightweight shockproof?? also, how much does the box need to fill it? i've read 1.8L for the r154 box, what about the w58??
Tom Kneebone
factory 5 spd TT : Auto TT
Tuesday, January 03, 2006 - 03:03 am, by:  Tom Kneebone (Tomk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shane Ilich wrote on Tuesday, January 03, 2006 - 01:27 am:
Now you've got me wondering if I am filling it right. I put the original 3.9 odd litres in the box and it did not flow out the filler and have just added another litre and still nothing comes out????
I remember reading that the R154 was about 3.5 to 4 litres which is why I was not too worried about the first fill not flowing out the hole.
Tom Kneebone
Tuesday, January 03, 2006 - 03:06 am, by:  Tom Kneebone (Tomk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And with that I am no longer a tinkerer ( sounds like something you do when you're alone...
in a room...
just you and you're computer...
Tom Kneebone
Tuesday, January 03, 2006 - 03:20 am, by:  Tom Kneebone (Tomk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
While I'm on a roll, Shane I drove the car for 18 months with the shockproof in it and it was always a little clunky in the changes unless I thrashed it then it got really smooth for a while?? It was never hard to change but noticeably smoother after letting the car have it's head for couple of changes. Don't know if this is a characteristic of the oil or an indication it needed more in the box??
Todd Williams
JZA70 R (BLMQZ)
Sunday, January 29, 2006 - 05:19 pm, by:  Todd Williams (Jza70_r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think i pumped 3.5 L in my R154 before it started to spill out of the overflow hole.
It is important to have the car dead level when filling the cars vitals. Obviously.
