  SoarerCentral * General Soarer Chat * Another soarer cheat unlocked? Previous Previous    Next Next
Vinod Param
Wednesday, May 10, 2006 - 06:20 pm, by:  Vinod Param (Vparam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This might have been mentioned already, but guess what I accidentally figured out when driving around in the rain?
With the soft touch wiper stalks in the V8 if you want to go straight from any wiper speed to off (instead of tapping the stalk multiple times) all you do is push the stalk towards the dash, let go and then very quickly push the stalk towards the ceiling. Instant off!
The same idea also works you want to go straight to full speed: Push stalk towards dash, let go, and quickly pull stalk towards the floor.
V8 manual
Wednesday, May 10, 2006 - 06:32 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On '91-93 cars, pushing the lever toward the dash will squirt water over the screen from the second washer bottle. On our cars (mine is '94 and yours '96) we sadly lack that wonderful second bottle so I guess some of the switching still exists and serves to interrupt the normal operation of the wipers so they go from some speed to phantom wash to off.
Dave Hart
Waikato
UZZ32
Wednesday, May 10, 2006 - 06:33 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just pull mine down for longer than just a flick and that seems to skip straight to fast.
Luke Nieuwhof
Wednesday, May 10, 2006 - 08:50 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Geez I was reading that and expecting to see:
Vinod Param wrote on Wednesday, May 10, 2006 - 06:20 pm:
With the soft touch wiper stalks in the V8 if you want to go straight from slow speed to fast all you do is push the stalk towards the dash, let go and then very quickly push the stalk towards the ceiling. Instant speed! The rear rocket boosters are activated and provide a short term acceleration of 5Gs. For this to work however your car must have the flare as this is where the rocket fuel is contained.
UZZ-32 V8 Soarer #138
Wednesday, May 10, 2006 - 09:51 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is actually a 2 stage switch. Push it up till it beeps/you feel resistance it goes 1 stage, keep pushing it will go a bit more and that's all on or all off depending which way you push it.
Applies to 'soft touch' style controls.
Vinod Param
Wednesday, May 10, 2006 - 10:54 pm, by:  Vinod Param (Vparam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oops.. Dan is right. All we have to do is push it further than normal and it goes straight on or off.
Wish I spent more time playing with my stick.. ahem..
Mark Donovan
Auckland
Soarer V8 Limited
Saturday, May 13, 2006 - 09:34 am, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what's the reason or advantage for the second bottle?
Alan Carter
Saturday, May 13, 2006 - 10:22 am, by:  Alan Carter (Alky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe you can have one with just plain water in it for rinsing and the other with detergent in it for washing off the bugs.
Saturday, May 13, 2006 - 10:44 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's what I do.
I have straight (as opposed to GAY) water in my front bottle, and a screen-wash mix (Bars Bugs etc) in the main bottle.
Alan Carter
Saturday, May 13, 2006 - 10:56 am, by:  Alan Carter (Alky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So now you're on the wagon, you've stopped filling the second bottle with JB?
Saturday, May 13, 2006 - 11:19 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey yeah, that'd be cool.
You could have a tap thingy just above the cup holder, and the booze would stay nice and cool in the air stream............shame I don't booze no more
