  SoarerCentral * General Soarer Chat * Coding help!!! Previous Previous    Next Next
Rob Andreacchio
UZZ31 V8
Reg: 01-2005
Wednesday, August 10, 2005 - 12:59 am, by:  Rob Andreacchio Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Having some compatibility issues with IE and firefox...
here is the code:
<OBJECT ID="mediaPlayer" CLASSID="CLSID:22d6f312-b0f6-11d0-94ab-0080c74c7e95" CODEBASE="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cabVersion=5,1,52,701" STANDBY="Loading Microsoft Windows Media Player components..." TYPE="application/x-oleobject">
<PARAM NAME="fileName" VALUE="http://www.mystore.com/test.wma">
<PARAM NAME="animationatStart" VALUE="true">
<PARAM NAME="transparentatStart" VALUE="true">
<PARAM NAME="autoStart" VALUE="false">
<PARAM NAME="showControls" VALUE="true">
<param name="wmode" value="transparent">
<EMBED type="application/x-mplayer2" pluginspage = "http://www.microsoft.com/Windows/MediaPlayer/" SRC="http://www.mystore.com/test.wma" name="MediaPlayer1" AutoStart=false>
</EMBED>
</OBJECT>
In IE I get this:
In Firefox I get this:
any ideas??
Rob Andreacchio
UZZ31 V8
Reg: 01-2005
Wednesday, August 10, 2005 - 01:00 pm, by:  Rob Andreacchio Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well what a helpful bunch you lot are! hahaha
Wednesday, August 10, 2005 - 01:09 pm, by:  Peter Nitschke Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry, I don't have Firefox and I wouldn't have a clue. But at least you know I read your post :-)
Wednesday, August 10, 2005 - 01:40 pm, by:  Benny Gammelmark Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need someone that knows web applications. I only do MainFrame Assembler and Cobol. Sorry.
And I second Peter.
Soarer GT-L (4.0 V8) and is300 (3.0 VVT-i 6)
Wednesday, August 10, 2005 - 01:58 pm, by:  David Vaughan Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you are patient I can farm the problem out to Software Engineering students at ANU but there is unlikely to be an answer before tomorrow. They will probably just ask why you are using WMP.
Wednesday, August 10, 2005 - 03:43 pm, by:  Peter Nitschke Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil, isn't that easily rectified with the use of FDISK?
Wednesday, August 10, 2005 - 04:15 pm, by:  Benny Gammelmark Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
FDISK is definitely the go You will never have ANY errors on your PC after that.
Rob Andreacchio
UZZ31 V8
Reg: 01-2005
Wednesday, August 10, 2005 - 06:23 pm, by:  Rob Andreacchio Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
fdisk...that's like defrag yeah??
Wednesday, August 10, 2005 - 06:27 pm, by:  Peter Nitschke Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah, that sounds about right :-)
Jarrod Spiga
Wednesday, August 10, 2005 - 06:38 pm, by:  Jarrod Spiga Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And in Linux, I get....
Jason Kingsmill
UZZ31 Soarer V8
Wednesday, August 10, 2005 - 06:52 pm, by:  Jason Kingsmill Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"FDISK is definitely the go You will never have ANY errors on your PC after that"
Only one error: "Invalid system disk"
Wednesday, August 10, 2005 - 07:32 pm, by:  Benny Gammelmark Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
At least you'd know why.
Peter Burrett
2.5 VVTi ST
Wednesday, August 10, 2005 - 07:45 pm, by:  Peter Burrett Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Clearly the problem is in the CPU.... there is nothing in the code that could cause even the slightest error....... but that doesn't mean that perfect code will give perfect results...let me take you back down memory lane.... we had a 1401 and it was working purrfectly..... we ran the same job twice and we got very different results..... bad situation; we all believed that software ALWAYS behaved the same way each time it was run.... SO if you got different results ....... it was a HARDWARE problem......... but then we discovered that software is time and date sensitive.... which invalidated our rule that it always would produce the same results...... since then (about 1969) there has been a seemingly endless series of technological failures which are all attributable to the blurring of the boundary between hardware and software... the result is that no one has the slightest fcuking clue where to look when the system breaks........ stiff S**T for the astronauts, even if they did make it back last night
Jeff Wilkins
JZZ30 GT-TL
Wednesday, August 10, 2005 - 09:55 pm, by:  Jeff Wilkins Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Firefox doesnt seem to enjoy much embedded vid content. I was having issues watching some Drift vids from the US the other night. Same deal, just a black screen. :-(
Hanré Van Rensburg
Thursday, August 11, 2005 - 01:09 pm, by:  Hanré Van Rensburg Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Firefox is open source so not everyone codes their sites etc to support it...
Thursday, August 11, 2005 - 01:21 pm, by:  David Vaughan Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Umm, they asked why are you using WMP? Anyway, no-one spotted any obvious problem with the code so one is lead to the conclusion that one or the other of Microsoft and mozilla.org (Firefox) does not play nicely with the other. Anyone want to have a guess?
Hanré Van Rensburg
Thursday, August 11, 2005 - 01:42 pm, by:  Hanré Van Rensburg Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
AFAIK Microsoft didn't design WMP for use with things non-Microsoft so it won't be fully compatible with Firefox.
I'm not that 'up' with coding myself at the moment but I say blame on the person who designed/coded the site...
WMP works flawlessly on many other sites using Firefox and other open source browsers so someone didn't their job properly.. :P
Rob Andreacchio
UZZ31 V8
Reg: 01-2005
Thursday, August 11, 2005 - 02:07 pm, by:  Rob Andreacchio Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
tis ok... .i have chosen a different method after all the mucking about.. thank you all for your help :-)
Peter Burrett
2.5 VVTi ST
Thursday, August 11, 2005 - 05:41 pm, by:  Peter Burrett Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not that there was much there for you to harvest GRYMM
