  SoarerCentral * General Soarer Chat * New car Previous Previous    Next Next
Damian Ware
Camry
Saturday, June 10, 2006 - 05:38 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pick up my new soarer today, 92 TT.
Runs great no problems so far... touch wood it will stay that way.
Damian Ware
Camry
Saturday, June 10, 2006 - 05:42 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I paid more than I should have for it but I decide it was worth the extra money to get one with all the options and low km's.
It has the standard door trim and vent cracks other than that it is quite clean.
Saturday, June 10, 2006 - 06:13 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice one mate !!
Post up some info and pics on your new toy .
Let the fun begin.
Damian Ware
Camry
Saturday, June 10, 2006 - 07:14 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes peter I have done a search but I cant find the details for the diagnostics. Which pins do I short out with a paper clip.
As to pics there is not much to see just a regular green 92 TT.
As far as I can tell it has all the options available for a TT except traction control and drivers airbag.
Options Sunroof, ABS, cruise, LCD rear vison mirror, ultrasonic folding mirrors, TEMS, factory sub, electric seats cant think of anything else.
Saturday, June 10, 2006 - 07:31 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Standard diagnostics, obtained by connecting Tc and E1 on the engine diagnostic port and turning on the ignition.
Engine diagnostics, obtained by connecting E1 and TE1 on the engine diagnostic port and turning on the ignition.
Damian Ware
Camry
Saturday, June 10, 2006 - 10:12 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Peter, I will play with it in the morning and see what it comes up with.
Damian Ware
Camry
Sunday, June 11, 2006 - 09:40 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I started the car just before, no smoke can out of the exhaust pipes but the dash is dead.
The bottom section comes up red and the rest is simply not there. I cant read or see anything, please help.
Damian Ware
Camry
Sunday, June 11, 2006 - 09:49 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have checked all fluid level which are perfect.
Battery voltage is fine 12.3V.
It has done 20kms since I filled it up with fuel.
What else could be wrong? Will this go away if I let the car warm up?
Damian Ware
Camry
Sunday, June 11, 2006 - 12:35 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok I got that problem sorted the battery as soon as it is put under load drops to about 11.5V so it is stuffed.
I have just used jumper leads to get it going and I will get a new one tuesday.
I have also run the diagnostics and it came up with only one error code for standard and engine diagnostics.
I am unable to find the code in the list (link below) I will post a pic could somebody please assist me to find this error code.
http://members.westnet.com.au/web/rbaird/warning.htm
Damian Ware
Camry
Sunday, June 11, 2006 - 01:02 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anthony Matthews
Soarer GT Limited V8
Sunday, June 11, 2006 - 02:12 pm, by:  Anthony Matthews (Gajet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm gonna take a guess and say "diag mode". The second bit definitely looks like mode to me. Could be wrong (frequently am)
Damian Ware
Camry
Sunday, June 11, 2006 - 02:53 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nothing else came up after I hit the scroll button just ABS OK, SUS OK, EFI OK, CRUISE OK
I guess this is a good thing.
No errors to worry about.
Damian Ware
Camry
Sunday, June 11, 2006 - 03:11 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is there anything else that has to be done to read the error codes.
Have I missed something.
Sunday, June 11, 2006 - 04:15 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can't find a match for that klingon error anywhere. :-(
Anthony Matthews
Sunday, June 11, 2006 - 04:21 pm, by:  Anthony Matthews (Gajet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't think it's an error. Wouldn't it be in red if it was?
Ken Cornell
4.0GT V8 Soarer
Reg: 01-2006
Sunday, June 11, 2006 - 04:22 pm, by:  Ken Cornell (Dunadan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought errors where in red?? or is that just my model?
Ken Cornell
4.0GT V8 Soarer
Reg: 01-2006
Sunday, June 11, 2006 - 04:23 pm, by:  Ken Cornell (Dunadan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damn Anthony, you just beat me!!
Damian Ware
Camry
Sunday, June 11, 2006 - 04:23 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If I do a ECU reset that will clear all the stored error codes.
I will do that later and see if it comes up with anything.
As for now busy trying to get my other car preped for sale.
Monday, June 12, 2006 - 02:00 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anthony IS right...........it says "Diagnostic Mode".
