  SoarerCentral * General Soarer Chat * Storing Previous Previous    Next Next
Mike Bradberry
V8 UnLimited
Saturday, August 02, 2008 - 10:57 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do you think it is necessary to disconnect my battery for just 3 weeks storage?
Ben Lipman
Soarer TT manual
Saturday, August 02, 2008 - 11:20 am, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No.
I leave mine for upto 6 months at a time. As long as the thing is in good working order and has no 'voltage leaks' you should be A-OK.
When I was in Darwin I was a bit more careful, due to the high heat and evaporating battery fluid problems. I still left it for up to two months at a time up there with no issues.
For me not having the alarm on whilst I'm away (which is a lot) is more of a concern.
XTR T-66 Turbo
Saturday, August 02, 2008 - 01:05 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
BUt then again its not really THAT hard to disconnect a battery... so why risk draining it?
As long as your car is parked in a good lock up garage and you dont NEED to have your alarm on (if you have one)
Mike Bradberry
V8 UnLimited
Saturday, August 02, 2008 - 03:52 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Both good points guys. I think I'll just leave it connected as the battery is new and the car will be in my garage.
Saturday, August 02, 2008 - 04:53 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
James Harris wrote on Saturday, August 02, 2008 - 01:05 pm:
I would still prefer to have the alarm onm even if its locked up... wouldnt want them to have easy access if they got into the garage!
Tuesday, August 05, 2008 - 10:07 am, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Id leave the battery connected and stick the car on chassis stands so that the tyres dont warp.
*shrug*
Mike Bradberry
V8 UnLimited
Tuesday, August 05, 2008 - 12:22 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe if I just do burnouts it'll make them round again.
Oh, then there's the front ones to worry about.
Tuesday, August 05, 2008 - 03:30 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
FULLI SYK!
Peter Scott
qld
Reg: 08-2008
Wednesday, August 06, 2008 - 11:57 am, by:  Peter Scott (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Mike You can leave it at my place,as long as it has a full tank of gas,i will make sure to keep your tyres round to. No burn outs or prise drop.
Mike Bradberry
V8 UnLimited
Wednesday, August 06, 2008 - 03:20 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What a great idea Peter. How much would you charge me to do that?
Peter Scott
qld
Reg: 08-2008
Thursday, August 07, 2008 - 12:16 am, by:  Peter Scott (Scotty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does $14,000 sound fair to you Mike.
What do you think fellow soarer Fans.
Brenton Trafford
V8 Limited - UZZ31
Thursday, August 07, 2008 - 09:18 am, by:  Brenton Trafford (Traff) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm sounds fair, though does it include polishing it (and his car)??
Dave Billings
Louisiana
SC 300, 2JZ-GE, 5 Speed; Porsche 993 Strozek; Porsche 911 Cabriolet; Honda Civic 2.0 IVTEC Integra; Infinity QX4; Jaguar S-Type 4.0
Reg: 06-2007
Thursday, August 07, 2008 - 12:08 pm, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brenton Trafford wrote on Thursday, August 07, 2008 - 09:18 am:
Mike Bradberry
V8 UnLimited
Thursday, August 07, 2008 - 12:13 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
For that money, you can polish what you like.
