  SoarerCentral * Kiwi Corner * Parts * Anyone wrecking a 91 soarer in NZ Previous Previous    Next Next
Trevor Neilson
tauranga
v8
Wednesday, April 11, 2007 - 05:01 pm, by:  Trevor Neilson (Anarot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
need the bootlid gas stays and the speedo sender off the gear box (auto/manual/6/8) they all should be the same.
Timothy Barnes
BOP
MR2
Wednesday, April 11, 2007 - 06:02 pm, by:  Timothy Barnes (Timmo1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are a couple on trademe
for example:
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Engines-drive-trains/auction-9 5232278.htm
Darryn Dewar
Gisborne
UZZ30 Soarer
Wednesday, April 11, 2007 - 06:19 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Buy new gas stays and save yourself a heap of headaches (BNT should stock replacements if the price at Toyota puts you off) And which speed sensor are you after??
Trevor Neilson
tauranga
v8
Wednesday, April 11, 2007 - 06:45 pm, by:  Trevor Neilson (Anarot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi. i need the speedo sender. it's the one that is held in by 2 screws at the end of the speedo gear (12mm bolt) . it has 3 wires going to it.also need the radiator top bottle (where the radiator cap goes).
Hanré Van Rensburg
Auckland
Thursday, April 12, 2007 - 05:38 pm, by:  Hanré Van Rensburg (Silent_knight) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Top Tank?
Buy a new one, you don't want to go 2nd hand with radiator type stuff...
Rod Quaife
Waikato
Thursday, April 12, 2007 - 05:59 pm, by:  Rod Quaife (Rod_quaife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Trevor I see someone wrecking 1991 V8 Soarer in trade and exchange this week, but he may want to quit whole car. Appears to have been in prang and wanted I think $1800 for it. Anyway if you interested have a look under parts section in Trade and Exchange. Cheers Rod.
Darryn Dewar
Gisborne
UZZ30 Soarer
Sunday, April 15, 2007 - 05:12 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a spare top tank, but as Hanré said you'd be better off going new....(plus I'm a parts hoarder from way back)
Will have a check on the gearbox sensor when I get a chance.
Trevor Neilson
tauranga
v8
Sunday, April 15, 2007 - 07:21 pm, by:  Trevor Neilson (Anarot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi darryn; that would be great if you could check for the speed sender. even if i could borrow it, as i'm not 100% that it is the problem. (98% though). doing this car on a budget, so have to go s/h. how much do you want for the top tank (square box, with rad cap and 2 outlets).you can get me at
bophorie@xtra.co.nz thanks trevor
