  SoarerCentral * Kiwi Corner * Parts * WTB: Starter Motor Previous Previous    Next Next
Soarer Limited UZZ31 V8
Friday, March 27, 2009 - 06:10 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello chaps.
I'm after a functioning 1UZFE starter motor thats complete.
Mine was working great in the bench test after rebuilding it but then 2 months later when I tested it in the car something was wrong, tried everything to make it go with no avail.
So if anyone has a starter or know where I can get one send me a message on here.
Matt Petersen
NA
Reg: 01-2008
Friday, March 27, 2009 - 06:25 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is probably cheaper to take it to an auto sparky and get it professionally looked at.
If you did the rebuild yourself it's possible it's gone back together incorrectly and could be a simple fix.
I rebuilt mine and they are pretty straight forward to do.
Matt.
Friday, March 27, 2009 - 12:47 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, Its just strange, I tested it correctly after putting it back together, and it worked like it should, motor ran and the solenoid pushed the gear out.
Tried it last week and it didnt work, like wise in the car.
Might pay to take it too one, see if they can work it out. Thanks Matt.
Auckland
UZZ31 Soarer
Reg: 03-2009
Sunday, March 29, 2009 - 02:50 pm, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does it sound like its ingageing when you turn the key? and did u apply load to the gear when you bench tested it?
Thursday, April 09, 2009 - 04:56 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha, in my foolishness in December when I put it back together and tested it, I didnt put load on the gear while testing.
After doing it this week I found I had put the over-running clutch in the wrong way!
All is well now. :-)
Farking hell!
Saturday, April 11, 2009 - 08:23 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool, so she's back on the road?
