  SoarerCentral * Kiwi Corner * Parts * Toyota control arm bushes Previous Previous    Next Next
Shyam Purushothman
Dorkland
2jzgte toyota Soarer
Wednesday, June 10, 2009 - 05:38 pm, by:  Shyam Purushothman (Zulu24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
is it at all possible to source bushes without the control arms? I was quoted well over $2000 for nolathane setup inc labour, this was for the full monty but then I have also heard about the ride quality being compromised:-(
V8 Ltd manual
Wednesday, June 10, 2009 - 06:37 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is what you need on
www.vftbushes.com? If so, it beats nolothane at any price.
Evan Kaio
Beautiful sunny good @ rugby Wellington
'91 UZZ31
Reg: 01-2007
Thursday, June 11, 2009 - 03:48 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, as David says.
I did the front upper and lower control arm bushes and steering rack bushes from VFT.
Very happy with the result.
Mark Donovan
Auckland
Tuesday, June 16, 2009 - 06:39 am, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll chip in and recommend VFT as well - I replaced every single one of my bushes with VFT bushes and it is worth every dollar to get the brand new feel again.
Tuesday, June 16, 2009 - 10:04 am, by:  Daniel Lee (Son_gokou) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got quoted from Toyota for the front upper control arm - $485 Each!
Unless your ball joints are stuffed, then you have to replaced the control arms.
Otherwise you can just replaced the bushes.
Shyam Purushothman
Dorkland
Friday, June 19, 2009 - 10:13 pm, by:  Shyam Purushothman (Zulu24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark how much did the bushes cost inc p&p to your doorstep? And for that brand new feel, did you replace steering rack and diff mount ones as well?
Im trying to keep things local as everytime I get stuff from o'seas i get stung tax
Warren Day
Pukekohe
jzz30
Reg: 11-2007
Saturday, June 20, 2009 - 08:32 am, by:  Warren Day (Da_funk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shyam, go to SAS (shock absorber services) in manukau. they fit new bushes to your control arm. You will have the bring the arm to them thou.
Shyam Purushothman
Dorkland
Saturday, June 20, 2009 - 09:11 am, by:  Shyam Purushothman (Zulu24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Warren me ol mate lol howsit going? This SAS outfit (sounds like special air service ninja styles...do they use poly/nolathane or do they do close to oem specs?
Evan Kaio
'91 UZZ31
Reg: 01-2007
Saturday, June 20, 2009 - 01:38 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Front upper and lower control arm bushes, also steering rack bushes were $655 AUD all up.
