  SoarerCentral * Kiwi Corner * Parts * Headers on Trademe (13 Oct '10) Previous Previous    Next Next
Mark Donovan
Auckland
Tuesday, October 12, 2010 - 05:27 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just putting this here in case anyone is interested:
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Exhaust/auction-323714852 .htm
Beautifully made mandrel-bent, stainless steel exhaust headers intended for an American market (LHD)Toyota pick-up that uses the Toyota/Lexus V8.
Steve Latimer
UZZ32
Tuesday, October 12, 2010 - 07:17 pm, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Apparently they only have one cat!
Daniel Blomfield
South Island
Soarer Limited V8 UZZ31
Reg: 02-2010
Tuesday, October 12, 2010 - 08:15 pm, by:  Daniel Blomfield (Soarer_nz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
was hoping no one would notice hoping to get a bargain oh well too late
Paul Knox
uzz31 manual
Reg: 08-2009
Monday, October 18, 2010 - 08:03 pm, by:  Paul Knox (Surreal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe the Tundra headers wont fit a soarer ?
I just recently bought a set of IMF headers from the states , as Neil's (rush headers wont fit my setup , and I'm pretty certain these wont fit either ?
I think they are too wide, and will hit the Strut towers
Good luck to whoever is going to try and fit them if it's for a soarer , i hope it all works out!
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Monday, October 18, 2010 - 09:27 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Paul have a suss of my thread 'Christian's V8 Soarer' as a bloke for Neils headers with a W58 from memory. Something to do with the clutch fork?
Paul Knox
uzz31 manual
Reg: 08-2009
Monday, October 18, 2010 - 11:54 pm, by:  Paul Knox (Surreal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah , thanks , I'm pretty sure he had to get an adaptor made for the Clutch slave cylinder on the bellhousing. To make it all fit.
I also checked with Neil himself and he confirmed his Extractors won't fit , so i think that adaptor setup is a real Pain in the Ass.
I'll have a crack at getting these IMF extractors to work, if not then it's Tilton or Howe hydraulic release time.
gotta love being a pioneer !
cheers.
UZZ31 V8 LTD
Reg: 03-2009
Tuesday, October 19, 2010 - 09:20 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Howe Hydraulic release!
Matt Petersen
NA
Reg: 01-2008
Wednesday, October 20, 2010 - 04:13 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a Howe that I am going to run. Need to make up a spacer to position it correctly for the R154 input shaft length.
Matt.
