  SoarerCentral * Kiwi Corner * Parts * 2JZ-GE water pump needed Previous Previous    Next Next
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Thursday, April 21, 2011 - 11:18 pm, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My water pumps leaking,
Anyone wrecking a 2JZ Soarer? Does any other water pump fit on?
I'd like to buy your water pump if your selling one.
Thanks,
Blake Gloyn
manawatu
soarer JZZ30 TT
Friday, April 22, 2011 - 07:01 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dude buy new from toyota. they aren't expensive, given how long they last.
Mark Bryant
tasmania
2jz na/t and rs4 stagea
Reg: 08-2010
Friday, April 22, 2011 - 07:11 am, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yer i think i paid $120 for mine from bursons.
You should replace the cam belt why you are there.
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Friday, April 22, 2011 - 09:09 am, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys, thought they would cost a arm and a leg from Toyota. $120's not bad.
And yeah I'm going to replace the belt and tensioner while I'm at it.
But you wouldn't believe how incredibly hard it was to get the crank bolt off.
The lists of things I tried includes
power bar + stater motor
Y tool to hold the crank + powerbar with extension and 2 people on each end pulling (4 people in total).
180psi rattle gun from a tire shop (which they use to remove truck bolts).
I had to take it to my mechanic to help me after that, they tried
special hammer tool used to get bolts off
oxy acetylene + hammer tool
oxy acetylene + starter
in the end we put the car up on a hoist, opened up the hole in the gearbox shoved a giant crow bar into the flexy plate. got the nut nearly red hot with oxy acetylene and hug off the nut with a power bar yes the bolt supported a bouncing growen male for a few moments before it decided to finally come out.
What a mission, my mechanic said that was the hardest crank bolt they've ever tried to get off.
Tuesday, April 26, 2011 - 06:09 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, second hand water pump is like second hand loo paper. Don't go there.
If they have used that much heat on the crank bolt, they may have damaged the front seal. Replace it if in doubt.
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Wednesday, April 27, 2011 - 08:20 pm, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When they sell me a water pump is it just the front pumping assembly or the whole thing? as my water pump is leaking from the rear not the actual pump (front half)
Mark Bryant
tasmania
Reg: 08-2010
Wednesday, April 27, 2011 - 09:46 pm, by:  Mark Bryant (2jz_nat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
mine started leaking from the same place,there is a like a valve or some shiz there and this is where they leak.make sure you purchase the whole unit.
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Wednesday, April 27, 2011 - 11:10 pm, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
where did you buy yours from Mark? I have done a little bit of calling but have yet to call Toyota in fear of a huge price tag.
Blake Gloyn
manawatu
soarer JZZ30 TT
Thursday, April 28, 2011 - 07:46 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
under 100 bucks when i bought a 2jzgte one . make sure you call either manawatu toyota or rutherford and bond, ask for the toyspeed or supra club discount, respectively.
