Monday, May 23, 2011 - 08:10 pm, by: Lucas Waterworth(Gadget666)
I built a system for mine to replace the fuel pump, I used two diodes on the input lines to prevent voltage back flow, a transistor to amplify their signal, and a solid state relay to switch the pump on
Tuesday, May 24, 2011 - 02:51 pm, by: Rod Quaife(Rod_quaife)
Just priced a new fuel pump ecu with toyota and now asking $800 for one. What exactly does it do for that price. Lucas you should put up a tutorial on you mod
Wednesday, May 25, 2011 - 02:47 pm, by: Rod Quaife(Rod_quaife)
No not kidding that the price which came up on their computer so said I wasnt buying it. Be a good idea Lucas. Goodness knows what a new suspension airbag would cost now.
Thursday, May 26, 2011 - 01:54 pm, by: Rod Quaife(Rod_quaife)
Guys just for you info "Mad Sounds" Hamilton has some second hand fuel ecu's available if anyone interested. Contact Carl.
He also has some engine ecu"s he thinks but has recently given most of them away to a automotive firm, cant remember which one but if I get back to him next week he will have found out.
Friday, May 27, 2011 - 07:15 pm, by: Rod Quaife(Rod_quaife)
Lucas got one of those little fans today, is there room enough at the back to attach two of them to the heat sink of the fuel ecu. What sort of glue did you use to stick yours to the ecu. Do they get that hot you would need a special glue or could you just tape them to the back say with insulation tape.
Saturday, May 28, 2011 - 12:04 am, by: Lucas Waterworth(Gadget666)
I used zip ties, and spliced the fan into the pos and neg power in to the fuel pump ecu, I actually moved mine to the boot when I did this, so I can't say for sure, but there seemed to be plenty of room. I keep forgetting to photograph my setup, but I will get around to it before the car gets sold.
Saturday, May 28, 2011 - 05:30 pm, by: Rod Quaife(Rod_quaife)
Yes I would be James as long as they in good order so let me know a price. How long have they been out of your car. Mine are not giving me trouble but then I havent been using it as a daily driver since I have had it so are not many ks on the clock. Since I intend keeping the car they prob will in due course and now using it more frequently
Wednesday, June 01, 2011 - 05:47 pm, by: Rod Quaife(Rod_quaife)
Lucas finally got two of those fans and screwed them onto cooling plate on back. If you use screws just a fraction bigger than the width of one of the cooling spaces screw makes its own thread and holds very firmly, does not go into the unit.
