  SoarerCentral * Kiwi Corner * General Chat * No spark Previous Previous    Next Next
Dwayne Croslald
south island
soarer 2.5 tt
Reg: 10-2011
Saturday, October 22, 2011 - 09:50 am, by:  Dwayne Croslald (Earplugs1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
jumped started the soarer back to front now got no spark have changed all of the fuses an no joy please help
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Saturday, October 22, 2011 - 09:57 am, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No Spark in wha? the spark plugs? and what do you mean jumped started the soarer back to front? battery relocation kit?
Darryn Dewar
Gisborne
UZZ30 Soarer
Monday, October 24, 2011 - 05:22 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You've probably wiped out one of the fusible links
Dwayne Croslald
south island
soarer 2.5 tt
Reg: 10-2011
Monday, October 24, 2011 - 09:51 pm, by:  Dwayne Croslald (Earplugs1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
THIS GUY I GOT THE CAR OFF PUT THE JUMPER CABLES THE WRONG WAY ROUND WAY ROUND POSITVE ON NEGTIVE AN YEA NOW CAR TURNS OVER NO SPARK AT PLUGS AN NOT TO SURE IF ALL THE DASH LIGHTS ARE WORKING AS I JUST GOT THE CAR PLEASE HELP OH AND I HAVE CHEECKED ALL THE FUSES THE 150AMP BLEW AN THATS IT REPLACED AN NO JOY
Andrew Poh
Waitakere
96 Soarer 2JZ-GE
Reg: 08-2008
Monday, October 24, 2011 - 10:08 pm, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've done that before on accident, and just blew some fuses, after I replaced them the car was fine again.
You should check all your spark plugs to see if its all or just 1
and also how did you test for spark? (cause some people don't know how)
BMW E36 Coupe 1UZFE V8 340i
Tuesday, October 25, 2011 - 07:56 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
CAPSLOCK :-)
Tuesday, October 25, 2011 - 08:48 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sue your school.
